Hello all, im thinking about buying a high quality data cable (gold plated) for my sbs-1e. Any here that is using a high quility data cable?
https://theshortener.com/ze (https://theshortener.com/ze)
I don't think a different USB cable will make any improvement. Why are you thinking of getting one?
Quote from: Anmer on April 22, 2020, 03:26:12 PM
I think my OEM cable has a broken wire inside, when i move the cable sbs-1e is losing connection
Sp you don't think a gold plated cable will give beter data transfer to my pc? So if i order a new cable i can stick with a standard 2mtr cable?
I think a standard USB cable will be just as good as a "gold-plated" one.
Quote from: Anmer on April 22, 2020, 03:46:29 PM
So for communictation betwin pc and sbs-1e a normal data cable (max 2mtr) is oke to use?
As long as you have the right connectors, you should be good.
I swap around and grab whatever USB cable is available. Never had an issue.
USB is used to carry digital data, so in theory if the data is corrupted the protocol should detect it and retransmit it. The gold plated connectors were much more important when the data transmission was analog and a poor connector could corrupt the data. I have always bought the cheapest USB cables and have not had any issues. I am not a hardware specialist but this is how I understand it works.
Thanks Steve, good explanation.
Quote from: Anmer on April 22, 2020, 07:21:53 PM
Anmer,
What is the maximum lenght of the usb cable i can use to connect to Basestation? Im thinking about buying this one:
https://www.aliexpress.com/item/33032571476.html?spm=a2g0s.8937460.0.0.39552e0eYdnDWv (https://www.aliexpress.com/item/33032571476.html?spm=a2g0s.8937460.0.0.39552e0eYdnDWv) and then the 3mtr one. Faramir told me this cable has less interference. I dont want to connect my sbs-1e with LAN and when im going to put new antenna on teh roof i want to make a shelf behind my computer chair and this is around 2.5/3mtrs away from my USB port in my desktop pc.
I'm not aware of a maximum length specified for an SBS but normally 5 metres is considered the limit for USB 2 cables and 3 metres for USB 3.
One can use longer "active" USB extension cables that amplify the signal.
Quote from: Anmer on August 27, 2020, 07:16:40 PM
Without using a extender, i can use the one i showed that i can buy on aliexpress?
Quote from: Pipo on August 28, 2020, 10:56:26 AM
I can't ofrfer any advice about the caBLE BUT IF IT'S ONLY 3 METRES LONG, IT
I have a FlightAware ProStick in the loft and recently bought this 10m USB lead to get it connected to my PC downstairs:
https://www.amazon.co.uk/gp/product/B011RCUH1G/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1 (https://www.amazon.co.uk/gp/product/B011RCUH1G/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1)
I know this isn't specifically what you were asking but thought it might be useful info for someone.
I'm not recommending this cable over any others, it is just the one I bought and it works OK for me.
I used a different 10m USB repeater cable for several (5 or 6) years but it became unreliable hence the recent purchase of this one as a replacement.
Keef.
Today i got the mail from aliexpress with a 3mtr usb cable for my sbs-1e, good quality and did a link test, it is working great. Now my sbs-1e can stand next to my scanner. Next week hope to build adsb antenna on my roof.
Thanks for the update. It's good to know it works for you.
It might be a broken/loose Soilder joint actually on the rear of the SBS box. Do not wiggle the USB port too much but if you just gently move the USB Port and you see some play that may be the reason.
Also if you have a faulty Power supply if its a Desktop PC this can cause it by not giving out enough umph to your box.
You can have a Desktop that works ok and it still can have a faulty PSU where usually the 5V rail has fails.
Cheers
Steven
Thanks Steven.
Pipo replaced the USB cable and that resolved the issue.
Quote from: ChiperHead007 on December 04, 2020, 10:59:47 PM
Cheers
Steven
Since i replace it with the new usb cable it is working great again, no los of connection since then, and the distance betwin pc en sbs-1e is 1mtr.
