Hex Codes and Registrations => Civilian Aircraft => Topic started by: rikgale on August 04, 2020, 09:43:55 PM
Title: HEX: 091004 Callsign: BFLAB2
Post by: rikgale on August 04, 2020, 09:43:55 PM
Hi All
Got the above hit today at about 10:21 somewhere within about 120mn of Truro, Cornwall. I did not get a hit on location and only got a couple of Mode-S messages.
I have no idea how to go about investigating a miss-code or if this is just a spurious signal or even a real aircraft, so any help and guidance welcomed. I have checked AIRFRAMES.org and google.
Many thanks,
Richard
Title: Re: HEX: 091004 Callsign: BFLAB2
Post by: Anmer on August 05, 2020, 08:42:29 AM
Hi Richard
If it was a spurios message, which it appears, the chances of tracking the source are usually zero.
BFLAB2 doesn't show up in FlightAware, which often shows unusual flight IDs.  And the hex code isn't assigned to a country.
These days, unlike 15 years ago, there are many websites tracking flights and entering just the flight ID in Google can often find a result, assuming the ID is a genuine flight.  I use Airframes.org as a first stop for hex codes,  It can identify the assigned country even if the database doesn't have a record for the specific code.
I checked my BaseStation.sqb and I don't have the flight ID or hex recorded.
Sounds like a spurious message.
Post by: rikgale on August 05, 2020, 12:55:14 PM
Thanks Anmer. I will pop it down a spurious ident in my database. I enjoy the reseasch, but when I get a callsign I do often wonder if there is was more behind it, hence asking someone at the end of a fruitless search... confirmation is always welcome.
Again many thanks
Richard
