Mode-S Receivers => Kinetic's SBS-1 => Topic started by: flyoverfred on November 02, 2020, 04:13:01 PM
Title: SBS1-er power supply
Post by: flyoverfred on November 02, 2020, 04:13:01 PM
Hi guys
I'm going to attempt the over Ethernet set up with my box, i'm not 100% sure which power supply I require and the last thing I want to do is blow my box up ! I'm based in the US, can anyone point me in the right direction to the requirements please ?
Title: Re: SBS1-er power supply
Post by: Anmer on November 02, 2020, 05:19:07 PM
Kinetic once advised for SBS-1eR:
I always recommend 12v DC Centre positive 300ma
Post by: flyoverfred on November 02, 2020, 07:28:54 PM
Quote from: Anmer on November 02, 2020, 05:19:07 PM
KMinetic once advised for SBS-1eR:
Thanks Anmer, I guess I would just stick some sort of usb adapter on the end of one then as a search doesn't seem to being any up with a USB connection as standard so to speak
Post by: Anmer on November 02, 2020, 07:45:40 PM
Isn't the connector a Mini-B?
Maybe a suitable adapter for the power supply?
Post by: Anmer on November 02, 2020, 08:20:27 PM
Sorry, the SBS-1eR had dual power options:
1. USB
2. DC supply with 5.5mm jack, 2.5mm pin
Post by: flyoverfred on November 02, 2020, 08:31:07 PM
Quote from: Anmer on November 02, 2020, 07:45:40 PM
looks like it, can't find one with that adapter on by default - thanks for the help
Post by: flyoverfred on November 02, 2020, 08:32:25 PM
Quote from: Anmer on November 02, 2020, 08:20:27 PM
1. USB
Oh, that changes things - I'll find something from that - thanks  :)
Post by: Anmer on November 02, 2020, 09:31:56 PM
I've used variable DC supplies that come with a range of connectors.
Like this:
https://www.amazon.co.uk/Universal-Switching-Household-Electronic-Speakers-Black/dp/B0851K8XGY/ref=sr_1_10?crid=6350HGQ2X8MN&dchild=1&keywords=dc+power+supply+variable&qid=1604352574&sprefix=dc+power+supply%2Caps%2C189&sr=8-10
Post by: flyoverfred on November 02, 2020, 09:45:32 PM
Quote from: Anmer on November 02, 2020, 09:31:56 PM
Like this:
perfect, i'll find similar over here, appreciate the link  :)
Post by: flyoverfred on November 14, 2020, 05:21:37 PM
Like this:
Hi Anmer,
would this work ?
https://www.amazon.com/dp/B07925DXC3/ref=syn_sd_onsite_desktop_145?psc=1&uh_it=df33ee4a14e5305aee8aa49107a4a8da_CT&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzTTQ3WEVFOVU1VTZNJmVuY3J5cHRlZElkPUEwMzk2MTczMUJONTBDQk1SNU9HMyZlbmNyeXB0ZWRBZElkPUEwOTExOTc1M0E0RUpXTEFWUTJSQSZ3aWRnZXROYW1lPXNkX29uc2l0ZV9kZXNrdG9wJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
Post by: Anmer on November 14, 2020, 05:30:06 PM
Check the jack socket and pin size.
Post by: IanH on November 15, 2020, 12:01:26 AM
I have only ever used the USB-B connector on my SBS-1e.
Something like this:
https://www.amazon.com/UGREEN-Charging-Controller-Players-Receiver/dp/B00P0GI68M/ref=sr_1_3?dchild=1&keywords=usb-b&qid=1605398333&s=electronics&sr=1-3
with a USB phone/tablet charger.
Safer than finding the correct PSU.
Post by: Anmer on November 15, 2020, 08:20:50 AM
@ flyoverfred
Are you planning to use the power supply to feed the downstream PoE connection?
Post by: flyoverfred on November 15, 2020, 05:12:04 PM
Quote from: Anmer on November 15, 2020, 08:20:50 AM
@ flyoverfred
Hey Anmer, I'm not 100% sure what that means but my plan is to mount my aerial in the attic and run the sbs1-er over ethernet - so i need to power the box with a plug rather than the usb
Post by: flyoverfred on November 15, 2020, 05:12:59 PM
Quote from: IanH on November 15, 2020, 12:01:26 AM
yeah that's how i've always done it but I can't do that going forward as per the post above
Post by: Anmer on November 15, 2020, 05:32:45 PM
So the antenna is in the attic alongside the SBS-1eR, where you have mains power?  I assume Ethernet into the SBS-1eR and the other end into a network access point?  Or direct to PC?
If the above SBS-1eR location is correct, you need to power it using a suitable DC supply using either the jack socket (as I described) or a powered USB as IanH suggested.  Both should work and easy to test the later.
Post by: flyoverfred on November 16, 2020, 04:08:09 PM
Quote from: Anmer on November 15, 2020, 05:32:45 PM
yeah mains power in the attic, ethernet to a access point then into the pc from there
Post by: Anmer on November 16, 2020, 04:20:30 PM
I would think either option will power your SBS-1eR though I'd prefer a configurable DC output and jack connection.  Never sure what output you'll get from USB.
