Mode-S Software => Virtual Radar Server => Topic started by: gonzalu on December 04, 2020, 07:46:25 PM
Title: Does anyone have the Custom Country Flag content enabled?
Post by: gonzalu on December 04, 2020, 07:46:25 PM
I am giving this mod a try:
https://github.com/dedevillela/VRS-Country-Flags
But I can't get the images to show... seems like the directory names and the JavaScript are different as is the instructions screenshot.
folder calls for ../images/web-country/... but actual folder name is "country"
Then there is the whole HiDpi and what not.. .the script points to Width and Height directories that do not exist :(
Thank you!
Title: Re: Does anyone have the Custom Country Flag content enabled?
Post by: Artilect on December 05, 2020, 05:28:29 AM
Oddly enough this was first plug-in I tried and worked right off the bat.  Subsequently other plug-ins have cause me many headaches.
Perhaps clear your cache and restart browser?
This one I ended up not using because of resizing the table still leaves a gap.  If the country label could be suppressed or hidden like the Transponder flag then would visually be more appealing.
Post by: gonzalu on December 05, 2020, 05:06:42 PM
Quote from: Artilect on December 05, 2020, 05:28:29 AM
Thanks... I kept at it and ended up figuring out I needed to give a root path LOL... didn't even bother to look at the FULL screenshot on the instructions :P
cheers!
Post by: motokops on January 02, 2021, 02:01:53 AM
Where is CountryFlag.html?
Post by: Anmer on January 02, 2021, 08:48:49 AM
Quote from: motokops on January 02, 2021, 02:01:53 AM
Have you seen this?
Post by: motokops on January 02, 2021, 09:13:46 PM
Yes. I saw and studied it, I can't find the file called CountryFlag.html in the download and CountryFlags.js it does not work.
I don't know how to configure it...
Post by: gunterb on January 02, 2021, 09:49:57 PM
The screenshot has not been updated. Replace the "CountryFlag.html" with "CountryFlags.js". Then it will work.
Regards g.
Post by: motokops on January 04, 2021, 11:07:32 AM
 It doesn't work for me.  ???
I will find another way to see the flags.
Post by: Anmer on January 04, 2021, 11:48:07 AM
Quote from: motokops on January 04, 2021, 11:07:32 AM
Did you install the Mod?
Post by: motokops on January 04, 2021, 02:19:55 PM
It work with this version:
https://github.com/dedevillela/VRS-Country-Flags/releases/tag/1.0.0.
Thx.
8)
