Mode-S Software => Basestation => Topic started by: Phil Harper on March 20, 2021, 05:50:01 PM
Title: ACTIVE DISPLY LIGHT
Post by: Phil Harper on March 20, 2021, 05:50:01 PM
Hi all,
can someone assist? I downloaded operator flags when active display lite was still in operation, but know i'm having difficulty in removing them,
i can find them in the operator flags folder or user data folder, has anyone got any ideas how I can remove them, as ive downloaded a new set and it SBS wont load up due to to many flags??
MTIA
Phil
Title: Re: ACTIVE DISPLY LIGHT
Post by: Anmer on March 20, 2021, 06:30:32 PM
Operator logos and silhouettes (.bmp files) are stored in the BaseStation -> OperatorFlags folder.
Do you see them there?
To remove them, either delete the files using Windows Explorer, or rename the folder, for example OperatorFlagsOld.  Then create a new, empty folder - "OperatorFlags" and install the files you now wish to use.
There is a Guide here:
https://radarspotting.com/forum/index.php?action=tportal;sa=download;dl=item43
Post by: Ospreyv22 on March 20, 2021, 08:48:34 PM
Or just go to where your operator logo file is in Basestation, open it and highlight the lot by keeping your finger on the left click on your mouse dragging it down the page until all highlighted and then right click so the box pops up and click on delete.
Then put your new flags into that folder.
Post by: Phil Harper on March 29, 2021, 06:35:20 PM
Ive tried that, The operatorflags folder is EMPTY, no files or folders or BMP's, ive even got it set to show all files, nothing in it.
ive moved the location of the folder and renamed it, yet when my sbs is running im still showing operator flags, ive no idea where the existing ones i have are, or how to access them to remove them, im baffled
Post by: Anmer on March 29, 2021, 06:50:55 PM
Quote from: Phil Harper on March 29, 2021, 06:35:20 PM
I suspect BaseStation is being launched from a different location.
If you launch Basestation from a desktop shortcut, right mouse click to view the shortcut Properties.
What do you see under Target?
Post by: Phil Harper on March 29, 2021, 07:06:19 PM
i see the following
Target type : Application
Target Location: BaseStation
Target : files(x86)\Kinetic|Basestation|basestaion.exe
Post by: Anmer on March 29, 2021, 07:18:47 PM
What's the folder (and path) for the OperatorFlags folder that's empty?
Post by: Phil Harper on April 01, 2021, 09:04:11 AM
I Think Ive sorted it, had to use the Active Display Lite to find out where the flags had been sent, and theres a utility to remove them on it ( glad i back up a copy )
Thanks for your assistance
