Mode-S Software => Basestation => Topic started by: Anmer on September 04, 2012, 03:52:03 PM
I see there's a new version of the Basestation.exe file in the Kinetic downloads. Version 174 "fixes" a number of issues in the previous release but I have no idea what these are and Kinetic isn't telling us.
Has it not heard of a Release Note?
Please note this is still a beta release and is only of value to SBS-3 customers although it will work with all SBS-1/3 receivers.
http://www.kinetic.co.uk/newsite/basestationdownloads1.php#6
Do we just replace the .exe file ?
Quote from: Ian K on September 04, 2012, 04:30:45 PM
Yes, but I always rename the original such as "basestation173.exe" in case I need to revert.
Ok Thanks Mike
Reported by Chris:
Label changes to the AM/FM/WFM Buttons on SBS-3 radio control panel
Label changes ON/OFF Buttons on SBS-3 radio control panel
SDR Channel display label changes
Audio control save setting now write channel 5 & 6 to ini file.
Not related specifically to v174, but ever since I have been using newer versions of Basestation that have been designed for the SBS-3, I have noticed that the auto-populate function linking from my database doesn't work anymore. I need to press F5 to fill the data. I see that the FD software also had this problem and an update was released. Does anyone know exactly what needed to be addressed to fix this, or "Chris" if you see this, what has changed within the Basestation software that has caused this issue ? Thanks for any input guys.
