Mode-S Receivers => Kinetic's SBS-3 => Topic started by: Urania on May 09, 2023, 02:30:18 PM
Title: Network pb when using my SBS3
Post by: Urania on May 09, 2023, 02:30:18 PM
I have updated with the last firmware my SBS3 box.
The box is running when using the USB cable directly connected to my PC.
When connected to my USB charger (5V/2.1A) the box seems to work, the network on my switch is blinking, but it doesn't catch any IP number from the DHCP server.
The DHCP lease is OK.
Any ideas ?
Thx
Title: Re: Network pb when using my SBS3
Post by: Anmer on May 09, 2023, 02:37:50 PM
The SBS-3 has a "fixed" IP address.  The default is 192.168.1.170.
It can be changed.  See Page 93 of the Reference Manual:
https://radarspotting.com/forum/index.php?action=tportal;sa=download;dl=item456
Post by: Urania on May 09, 2023, 02:51:52 PM
I must be blind today, I do not find the "non volatile memory setting" ....
In the settings of the basestation, I do have: display, data and hardware settings + data source, add on sdr puk ....
Post by: Urania on May 09, 2023, 02:59:04 PM
It appears suddenly ...
Post by: Urania on May 09, 2023, 03:56:25 PM
So I am able to change the IP number but it still doesn't show on my network.
The GW is ok, the IP is ok, there is a link. I cannot ping it too.
I have change the network cable without any change.
Ideas ?
Post by: Anmer on May 09, 2023, 04:05:59 PM
Can I check that it is an SBS-3?
What is your local IP network address range and what have you set the SBS-3 IP address to?
Is the Ethernet cable connected from the SBS-3 to a router or switch?
Post by: Urania on May 09, 2023, 04:17:29 PM
my network is a vlan: 192.168.206.0/24
it is connected to a switch with 192.168.206.251 as IP number
the ethernet light on the box is off
cannot ping it
blue box with writing SBS-3 on it .... :)
I have send attached files to you directly ...
Soft version: 1.2.4.184
Firmware version: SBS-3 build 119
Firmware options: 1 and 8 (??)
Post by: Anmer on May 09, 2023, 05:44:43 PM
Quote from: Urania on May 09, 2023, 04:17:29 PM
Does this mean the allowed IP addresses are only between 192.168.206.0 and 192.168.206.24?
And how are you powering the SBS-3?
The SBS-3 always needs to be powered using the USB socket. If you are going to connect via Ethernet rather than USB, you will need to attach an external USB power supply. It is recommended that the external supply is rated at 2.0 Amp (2000 mA) or greater. When the USB port on the SBS-3 is connected to a PC (and the orange USB light is on indicating a USB data connection), the Ethernet interface on the SBS-3 is automatically turned off to save power. Therefore you cannot connect using Ethernet if the SBS-3 is connected via a USB cable to a PC.
Post by: Urania on May 09, 2023, 05:59:29 PM
made a mistake, it is /26 instead ... So it suppose to be from 206.2 to 206.62 ...
I have change the IP of my box to 206.61 ... still do not show :(
And has I said on my first post: USB charger (5V/2.1A)
Post by: Anmer on May 09, 2023, 06:05:25 PM
Is the Ethernet cable OK?  And a patch and not crossover?
And you cannot ping the IP address?  Do you get a time out?
Post by: Urania on May 09, 2023, 06:33:21 PM
1)
I have connected the sbs3 via ethernet directly to my pc.
I was able to ping it. But no airplanes appeared.
2)
I have connected the sbs3 to my general network.
I am able to ping the sbs3.
Basestation is running and planes are appearing :)
Thx a lot for your support :)
Post by: Anmer on May 09, 2023, 06:36:26 PM
Great, so the SBS-3 is showing on your network.
Have you set the Basestation Data Source to "Use Network"?
Settings -> Data Source ->Use Network
But maybe I misunderstood your last post?  Is everything now working OK?
Post by: Urania on May 09, 2023, 07:02:41 PM
yep
