Miscellaneous => Other Topics => Off Topic => Topic started by: Tom(zulu10) on March 09, 2024, 10:32:17 AM
I think the site has been offline since March 7, 2024.
Very unfortunate, it was a top site to fill in the information for the aircraft on my SBS1. I also see in the title bar that the site is no longer secure, so I think it is off line.
Working ok for me here... http://www.airframes.org/
There does seem a lag in getting the new ones listed though..
try- https://rzjets.net/aircraft/ or https://blackswan.ch/aircraft
https://www.planespotters.net/
Quote from: Smudger98 on March 09, 2024, 10:42:27 AMWorking ok for me here... http://www.airframes.org/
Oke thanx for the info.
I've been away all week so not been visiting Airframes as normal. But the site does seem to be online at this time. SSL probably needs renewing?
Quote from: Anmer on March 10, 2024, 07:43:47 AMI've been away all week so not been visiting Airframes as normal. But the site does seem to be online at this time. SSL probably needs renewing?
SSL is being updated, but even then it doesn't work here in the Netherlands. keeps reporting that the site is not secure. I think that's why the provider is blocking him.
I have had issues accessing this site over the years. Whenever I have asked others have said it is working for them. I have found if I reboot my router it starts working again. I am in the UK so this may not help you in the Netherlands but it might be worth a try.
While reported as not secure I'm able to use the site. No problems at all.
Check you anti virus software is not blocking it
Quote from: mhm on March 12, 2024, 07:38:47 AMCheck you anti virus software is not blocking it
I have turned it off but it still doesn't work, continues to transmit without security and a blank image unfortunately.
