Forum Info => Forum Guidelines => Topic started by: AV61 on April 23, 2025, 02:45:53 PM
i have been using MODE S TWEAKER and I am now getting this message
MT_Settings.xml application controls contains invalid XML
Do NOT continue close app and fix this problem
Can anyone advise how to rectify this or has anyone got a link to download the program again
thanks
At what point do you get this message?
Mode-S Tweaker can be found here (https://radarspotting.com/forum/index.php?action=tportal;sa=download;dl=item501)
Hi Amner
as soon as it loads up I get the correct screen show up and that error message appears
Thanks. So as soon as you run MS Tweaker you get this message? Does MS Tweaker load OK or does the message prevent it?
Has anything changed recently, such as the location of your BaseStation.sqb file? What version of Windows are you running?
I fired up MS Tweaker earlier and it ran OK for me.
In the folder where you installed ModeS tweaker you will find a file named "MT_Setttings.xml" this contains all the settings you have set within the app.
Can you attach the file to this thread, or copy the contents of the file and paste it in a reply ? You can open the file using notepad or similar to copy the contents.
Cheers
Kelvin
