Mode-S Receivers => Kinetic's SBS-3 => Topic started by: Martin Waller on November 05, 2012, 08:01:26 PM
Title: SBS3 - Decoding Port 10001
Post by: Martin Waller on November 05, 2012, 08:01:26 PM
I'm looking at decoding data from port 10001 of the SBS-3. In particular I'd like to decode the Mode S Data Long Format packets.
I have access to the Kinetic API Reference Guide and I can see packates of type 0x05 being send by the SBS-3. Typically this data may look like:
10 02 05 00 E8 3D 3C A0 00 06 BC FB B3 45 24 7F
C4 8E 48 4C 53 10 03 B6 52
which is nicely bracketed by the DLE, STX, ..., DLE, ETX and CRC. That leaves me with the data in the middle:
C4 8E 48 4C 53
Which is a 0x05 packet - the Mode S Data - Long Format packet. The documentations suggests that this then breaks down as:
Byte 0 - Packet Type
Byte 1 - Not used
Byte 2 - 4 timestamp
Byte 5 - 18 14 bytes of Mode S Data
So the 14 bytes are:
A0 00 06 BC FB B3 45 24 7F C4 8E 48 4C 53
The last three 48 4c 53 seem to be the address code - possibly reversed.
My question is, does anyone know how to decode the rest of the packet? Is it encrypted, is it documented, can anyone provide any guidence on how to decode this please?
Many thanks
Martin
Title: Re: SBS3 - Decoding Port 10001
Post by: Martin Waller on November 06, 2012, 10:23:48 AM
Hello, many thanks to all that have read this message but I'm now sorted.
Martin
Post by: lanek on January 24, 2013, 10:42:14 PM
Hi Martin,
How did you end up decoding this message? I have contacted Kinetic support and asked them to provide documentation.
Lane
Post by: Anmer on January 25, 2013, 07:50:16 AM
Quote from: lanek on January 24, 2013, 10:42:14 PM
Kinetic has published an API:
http://www.kinetic-avionics.com/newsite/api.php
Post by: lanek on January 29, 2013, 10:25:45 PM
Yes, I have looked at the API Document v 1.03 and all it says is this
0x01 - ADS-B or TIS-B data (KAL_PKT_MODES_ADSB)
Byte 0 - packet type
Byte 1 - not used
Byte 2-4 - Rolling timestamp - in 50ns intervals
Byte5-18 - the 14 bytes of Mode S data.
As the original post asks, what is the Mode S data? I am still yet to receive a reply from Kinetic and it has nearly been 1 week.
Post by: Anmer on January 30, 2013, 07:36:26 AM
Quote from: lanek on January 29, 2013, 10:25:45 PM
I suspect you won't get a reply from Kinetic.  No one's heard anything from them for months.
Post by: acarslogger on January 30, 2013, 09:15:29 AM
Assuming the data on port 10001 is the same as the raw data output by Basestation on port 30006, then it's defined in ICAO Annex 10.
Google, or try this as a starter  http://legacy.icao.int/anb/panels/scrsp/docs/Doc.9871-E2-20110425.pdf  .
Good luck !
Stuart
Post by: lanek on January 30, 2013, 10:17:33 PM
Thank you every one for your comments.
I received a reply from Taylor Made RF, who stated that I need to refer to the following documents: DO-260/A/B or ED-102A
So far I am unable to find them. However, this looks like it will be useful.
Quote from: acarslogger on January 30, 2013, 09:15:29 AM
I think I have found the Annex 10 document to the one above here:  http://www.google.com.au/url?sa=t&rct=j&q=icao%20annex%2010%20digital%20data%20communications&source=web&cd=4&ved=0CD0QFjAD&url=http%3A%2F%2Fwww.bazl.admin.ch%2Fexperten%2Fregulation%2F03080%2F03081%2Findex.html%3Flang%3Dit%26download%3DNHzLpZeg7t%2Clnp6I0NTU042l2Z6ln1ah2oZn4Z2qZpnO2Yuq2Z6gpJCDeoB9fGym162epYbg2c_JjKbNoKSn6A--&ei=lpkJUb2qJKrjiAKV8YCQCw&usg=AFQjCNFvU1FqdsHNIImC2PG-2bSIGPJpXA&cad=rja
Post by: lanek on February 01, 2013, 01:35:55 AM
I have been informed that DO-260 is available from RTCA
http://www.rtca.org/onlinecart/product.cfm?id=512 and ED-102A from Eurocae http://boutique.eurocae.net/catalog/product_info.php?products_id=271 at a cost of $500-1000 each.
Post by: Anmer on February 01, 2013, 08:01:26 AM
Quote from: lanek on February 01, 2013, 01:35:55 AM
Or free in electronic format for RTCA members.
Post by: lanek on February 04, 2013, 12:14:39 AM
Yes, free. I was aware of that but I do not know any one with a RTCA membership.
