Mode-S Software => Active Display => Topic started by: charliebrown on November 28, 2012, 08:41:02 AM
Title: Microsoft.net Framework problem
Post by: charliebrown on November 28, 2012, 08:41:02 AM
I've started to have Microsoft.net Framework problems which end up with me being unable to shut down my PC except using the following:
Press Windows Key + R
2. Type "CMD" (without quotes) then press enter
3. Type "shutdown.exe -s" then press enter.
I have an SBS-1er, using Plane Plotter, AD Lite and Flight Display. Windows 7 64 bit version.
Error message .jpeg attached.
Any suggests what is going on here ?
Charlie
Error Reads:
"See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Data.SQLite.SQLiteException: The database file is locked
database is locked
   at System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt)
   at System.Data.SQLite.SQLiteDataReader.NextResult()
   at System.Data.SQLite.SQLiteDataReader..ctor(SQLiteCommand cmd, CommandBehavior behave)
   at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
   at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
   at System.Data.SQLite.SQLiteTransaction..ctor(SQLiteConnection connection, Boolean deferredLock)
   at System.Data.SQLite.SQLiteConnection.BeginDbTransaction(IsolationLevel isolationLevel)
   at System.Data.SQLite.SQLiteConnection.BeginTransaction()
   at ActiveDisplayLite.ActiveDisplayLiteForm.WriteOperational()
   at ActiveDisplayLite.ActiveDisplayLiteForm.Form1_FormClosing(Object sender, FormClosingEventArgs e)
   at System.Windows.Forms.Form.WmClose(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.5466 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
ActiveDisplayLite
    Assembly Version: 1.64.0.30
    Win32 Version: 1.64.0.30
    CodeBase: file:///C:/Users/Charlie%20Brown/AppData/Local/Apps/2.0/MX6BCEQX.O20/8E7X8GH1.A5A/acti..tion_d45369983457ba68_0001.0040_9d6c87df14f0c03c/ActiveDisplayLite.exe
Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.5420 (Win7SP1.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    Win32 Version: 2.0.50727.5460 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    Win32 Version: 2.0.50727.5462 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
    Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Data.SQLite
    Assembly Version: 1.0.65.0
    Win32 Version: 1.0.65.0
    CodeBase: file:///C:/Users/Charlie%20Brown/AppData/Local/Apps/2.0/MX6BCEQX.O20/8E7X8GH1.A5A/acti..tion_d45369983457ba68_0001.0040_9d6c87df14f0c03c/System.Data.SQLite.DLL
System.Data
    CodeBase: file:///C:/Windows/assembly/GAC_64/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Transactions
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/assembly/GAC_64/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Management
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
System.Web.Services
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
azluv_wl
vdnqibbp
System.EnterpriseServices
    CodeBase: file:///C:/Windows/assembly/GAC_64/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box."
Title: Re: Microsoft.net Framework problem
Post by: Bethsalem on November 28, 2012, 02:20:52 PM
Generic solutions which you may have already tried.
1. Try reinstalling Framework package via Microsoft Update
2. Use security scan to make sure that you're not infected with malware
3. Check that your RAM memory isn't damaged
4. Check that your hard drive is functioning okay
5. Rolling back any programs you may have installed that after you installed it/them you started noticing this problem.
6. Send what you've posted here to Microsoft's Win7 forum, you should get a quick reply
I hope any of the above was of use?
Best of luck
Post by: charliebrown on November 30, 2012, 05:49:36 PM
Hi Bethsalem,
I have tried Nos 1 to 4 that you suggested.
No 1 was the main suggestion on Windows 7 forum to correct this problem and I did a complete new install of Microsoft.Net Framework 4.
Problem still occurring.  Its seems to be either SQLite or Active Display Lite that is causing the problem.
I have reinstalled Active Display Lite but problem still there.  Strangely after I reinstall   Active Display Lite, the ADLite icon disappears from the taskbar permanently.
When I then uninstall Active Display Lite, the problem seems to have been resolved.
As I am running  SBS-1er, using Plane Plotter, Flight Display with my Windows 7 64 bit version, I'm not sure if I need to have Active Display Lite installed at all.
All very strange.   :-\
Charlie
Post by: IanH on April 03, 2013, 06:13:05 PM
Wasn't sure whether to add to this thread or start afresh.
But it's a Microsoft.net Framework problems with AD Lite so here goes.
Similar error message but not tried shutting down the PC yet.
The problem was ModeS 43C451 transmitted Registration as:
MISC|Not Found.
This was too long to be accepted so the error popped up and halted AD Lite. Closed down AD Lite and then restarted it - same error when re-transmitted.
Looks like AD Lite doesn't check to see if "Registration" lies within the bounds of the program.
Post by: Anmer on April 03, 2013, 06:33:53 PM
There are known issues with the GAS servers at this time affecting AD and AD Lite.
Post by: IanH on April 03, 2013, 08:16:21 PM
Yep seems like the explanation - just happened again.
