Mode-S Receivers => Kinetic's SBS-1 => Topic started by: Smudger98 on March 26, 2013, 03:39:21 PM
Title: Basestation Error.
Post by: Smudger98 on March 26, 2013, 03:39:21 PM
I seem to have a basestation error since the dongle install.. when i try an edit i m getting an error ii cant close or delete..
Every time i try to edit an aircraft display i get this error, I have tried to close BS an even re-booted the PC.. any help please..
Title: Re: Basestation Error.
Post by: Chris-G0WTZ on March 26, 2013, 04:15:12 PM
What are you using to run the dongle? Does it access the basestation sqb?
Post by: Smudger98 on March 26, 2013, 04:20:42 PM
Quote from: Chris-G0WTZ on March 26, 2013, 04:15:12 PM
Hi Chris,
Using SDR sharpe or SDR console for the radio and no.. it shouldn't touch BS in anyway.. ?
Smudger.
Post by: viking9 on March 26, 2013, 04:28:11 PM
Is anything other than Basestation accessing basestation.sqb - PP for example?
Post by: Smudger98 on March 26, 2013, 04:32:35 PM
No Tom.. I don't use PP, the BS programs are fairly much stand alone..
It more than likely just a coincidence.. im have a major disc spring clean out.. see if making a bit more room makes any difference..
Post by: Anmer on March 26, 2013, 07:12:16 PM
I get those messages whenever I'm using lots of applications that are sucking up the PC's memory.
Closing the browsers usually resolves it.
Post by: Chris-G0WTZ on March 26, 2013, 11:16:31 PM
Have you packed the database?
Post by: Smudger98 on March 27, 2013, 07:50:38 AM
Not packed it for a while i must admit Chris..
Wont get the chance to try it until Thursday as i wont be home until then.. will let you know how it goes -also in the middle of clearing out and saving away lots of non aircraft related stuff..
Thanks for all the responses.
Smudger.
Post by: Smudger98 on March 30, 2013, 09:16:46 AM
Packed the DB for a try.. still getting the error.. seems to a rolling error.. where as in the end it just wont close..
When i reload BS - it takes about 5-10 edits then whamo.. square one ..
Anymore suggestions welcome.. the CPU issue is solved so its not that.. :-\
Smudger.
Post by: Anmer on March 30, 2013, 10:25:19 AM
It's possible the database (Basestation.sqb) file is corrupted.
You could use an SQL utility, such as SQLite Expert Personal (free) to run a couple of checks?
Close Basestation, Reporter and SBS1 Populate.
Take a backup copy of the Basestation.sqb file.
Then, using the SQL utility of choice, open the Basestation.sqb file and execute these SQL commands:
PRAGMA Integrity_Check
Wait for this to complete.  If it reports "OK", run:
Vacuum
Alternatively, rename the Basestation.sqb file, start Basestation which will create a new, empty sqb file.  Edit the file as before and see if the errors occur?  If not, it may suggest the original sqb file has some corrupt
Post by: Smudger98 on March 30, 2013, 12:50:42 PM
Ran BS with a new SQB.. and seemed ok.. so i have now downloaded SQLite Expert Personal but need a hand with this..
Post by: Smudger98 on March 30, 2013, 01:37:29 PM
Running BS with new sqb for a while to see if the error happens again on this file..
Seriously chuffed off with this now..  >:( >:( >:( >:(
Post by: Smudger98 on April 08, 2013, 09:16:51 AM
Ok.. update time..
By process of elimination..
Stopped the windows error logger and the performance went up 100% and the processor went down from 100% to 2-4%,  ;D
With Anmers invaluable help and assistance via a remote session a new version of basestation was installed and the components put back 1 at a time.. all now working well and (touch wood) much better than before. Ran for 24 hours a day over the weekend and have been smashing the edits through with out any errors.
Thanks for all the help Mike.
Smudger.
Post by: Anmer on April 08, 2013, 09:24:11 AM
Thanks for the update.  Glad all is, touch wood/head, working OK now.
Sounds like something got corrupted in your original Basestation install.
