have a new Pc built by my grandson, this last couple of days I'm suffering the BSOD
I have only run two programmes basestation and Sbsplotter today and after about
1 and half hours windows crashed, so I loaded basestation and let it run and no [roblems
but with both running it crashed again, alas my grandson is abroad and wont be back until the weekend.
Any Ideas please
Running windows 7 64 bit
Does it crash if anything other than basestation and Sbsplotter are running?
Hi Neil
To be honest I've not tried other programmes yet, I just about to try Flightradar24
to see if this will cause it to crash
Will let you know and thanks for answering Neil
Kind regards
Tom
Is it Basestation and SBS PLotter or SBS1 Populate?
hello Mike
I'm in trouble again!!
I think I have found the problem! I have just had basestation running on it's own for over an hour now and no prblems I'v just opened Sbsplotter and after a short while windows crashed
I think that it's my fault because when I go to the shortcut a box came saying click run
which i don't have on the other pc
Tom
Tom, was the other PC64 bit?
I have problems with sbsplotter too, it crashes quite often on my systems, windows xp and windows 7 x64, on windows 7 x32 haven't had a crash so far but it only ran 12 hours.
I don't get the BSOD though, the program just gives an access violation message and must be closed as an option.
You could try "run as administrator", it seems to run longer before crashing for me that way.
Hi Mike and Kered
Mike, the other pc was 32bit and never had this at all
Kered, this the first time i've had a windows 64 bit machine
I know that basestation has been installed correctly as Anmer (Mike) did it for me
I ran basestation only last night and it only ran for about an hour and crashed
leaving a small box with some details in ,saying something about Appdata problem
Tom
Thanks to you both
Tom
Are you running SBSPlotter (to create a plot outline) or Gatwick Aviation Society's SBS1 Populate for registration lookup?
I am running Sbsplotter for the distances, I have very little on the new pc at the moment Mike
I have been running Flightradar 24 all morning with no problems following my grandsons return from Singapore aboard a A380
Tom
Thanks Tom.
SBSPlotter just reads the data on port 30003 so I woulldn't think it's causing the BSoD.
I thought it was at the off, but have since run basestation on it's own and the machine crashed after about an hour
I really don't know what to think
Tom
Maybe update the USB drivers.
In the Bssestation fo9lder is there a file called CDM20802_Setup.exe?
If there is, with Basestation close, double click the file.
yes there is
