498488 / 0454 / CEF699 / C297
EDIT: http://en.wikipedia.org/wiki/Czech_Air_Force
EDIT2: http://www.flightradar24.com/data/airplanes/0454
Is there a question?
yes it was an question. ;D
What is the question?
If you want to know, if Mode-S 498488 is reg 0454 - then yes, it is ;)
ich habe es schon in fr24 gefunden. ???
Try looking up the hex code at http://www.airframes.org/
a new one
477FF2 / Aircraft: 02 /flight: BRK98
ok ok.... is a war going on?!
I understand you are a new starter and like others on here I'm very willing to help with code tie-ups. But you must learn to first look up airframes.org and other sources like libhomeradar yourself.
Viking9 is correct.
There are many online resources where you can find hex code lookups. Or use a utility such as Active Display from the Gatwick Aviation Society.
You will find help here for hex codes that can'[t be found on these online sources but it will be better if you first try them yourself.
New Question.
QuoteAustria ;? ;OEIRP ;XA0000
Austria ;? ;OEIML ;XA0000
Austria ;? ;OEIMI ;GS0001
Austria ;? ;OEIIS ;XA0001
Austria ; ;OEIIS ;XA0001
Austria ;440135;OE-GMM ;GS0001
Austria ; ;OE-GMM ;GS0001
I see a lot Aircraft white "XA" and "GS" Flight Number but i found no Airline.
What i know is there are some Private Jets and Small Aircraft.
http://www.airlineupdate.com/content_public/codes/airlinecodes/iatacodes/iata_g.htm
http://www.airlineupdate.com/content_public/codes/airlinecodes/iatacodes/iata_x.htm
Try searching Airframes.org for the registrations, such as OE-IIS
the dont dnow what XA, GS are.
Quote from: Radio2.0 on October 24, 2013, 03:03:40 PM
Where are you seeing the information you posted?
In the Logfile that TellMe create.
I edit the source a little bit to get that information i want. *gg*.
What is the source of the data - what receiver and decoding software?
Quotewhat receiver and decoding software?
Terratec + Planeplotter
What's a Terratec? Another name for a buried RadarBox? (Only joking). :)
http://de.wikipedia.org/wiki/TerraTec
Flight Ids of GS0001, XA0000 and XA0001 are commonly used on acars by general aviation aircraft.
Acars messages contain the aircraft registration and a flight id - I assume these 'dummy' flight ids are factory default settings inside the acars avionics equipment.
Stuart
Quote from: acarslogger on October 24, 2013, 04:08:26 PM
Thanks Stuart.
Lol Mike am I missing something here ?
according to My search just done in airframes, it's an Avcon Jet, Gulf 5
Does "AE" mean US Airforce like: AE07ED ?
thx
OE-IRP Bombardier BD-700-1A10 Global Express GLEX 9106 L2J 440229 XPE - Amira Air 2001 2007-01 N10E active
OE-GMM Cessna 680 Citation Sovereign C680 680-0005 L2J 440135 MGR - Magna Air 2004 N52229 2005-04 N105SV active
XA0000 = ICAO24 address:
Here's 2 aircraft from your list, these are taken from Airframes.org
What about that the shuld be Military Flights?
AE07EA;95-0107 ;RCH966 ; 0.00000; 0.00000;31000; 0.0; 0.0;2013-11-09 11:17:30;11:17:30; 6;000.0; 0.0;*-;C17 ; ;2120; ;
AE117D;02-1111 ;RCH212 ; 0.00000; 0.00000;31000; 0.0; 0.0;2013-11-09 12:03:59;12:03:59; 6;000.0; 0.0;*-;C17 ; ;2131; ;
AE117A;02-1108 ;RCH425 ; 0.00000; 0.00000;38000; 0.0; 0.0;2013-11-09 13:25:37;13:25:37; 6;000.0; 0.0;*-;C17 ; ;6155; ;
AE07DE;93-0604 ;RCH555 ; 0.00000; 0.00000;33000; 0.0; 0.0;2013-11-09 16:50:23;16:50:23; 6;000.0; 0.0;*-;C17 ; ;2120; ;
AE1235;03-3124 ;RCH394 ; 0.00000; 0.00000;29000; 0.0; 0.0;2013-11-09 16:55:28;16:55:28; 6;000.0; 0.0;*-;C17 ; ;2154; ;
Hex codes are allocated in blocks and many AE codes will be allocated to US military.
We have previously suggested tools that you can use to check hex codes.
The first reach aircraft in your Mil list is decoded below:
Registration Manuf. Model Type c/n i/t ICAO24 Selcal Reg / Opr built test reg delivery prev.reg until next reg status
95-0107 McDonnell Douglas C-17A Globemaster III C17 P-32 L4J AE07EA RCH [MC] US Air Force USAF) 1995 1995 active edit
Remarks: named "Spirit of North Charleston". Damaged during landing in northern Iraq 2003-04-21, ran into construction equipment
[MODE-S] [HFDL
Please go to Airframes.org and put in the respective code that you want to decode and you will get all the information that
is currently available, it is so easy !!!!!
What is that Aircraft? ???
It's a gas turbine powered model helicopter.
I know but i can not find the reg.
Perhaps large aircraft models in Germany/Austria have their own registrations - I don't know - but you are in a much better position to find out.
I don't think so, not at least here in Spain. The only ones that can have a special registration are those "models" used as UAV.
In the short "Movie" the say this kind of Aircraft need there own Registration but on the official Page i cant find it:
http://www.austrocontrol.at/luftfahrtbehoerde/luftfahrzeuge/lfz_register/online-abfrage
Does any Train have that Flight Number:
DBB Deutsche Bahn (GERMAN Rail)
VRR Via Rail
We might be able to help if you presented the context of your question.
What have you seen, how and where?
Not quite sure if this is what your looking for :
VRR - Verkehrsverbund Rhein Ruhr : Regional Train Network in the Rhine-Ruhr Area.
Trainspotters in Germany should look at the official train radar website of the German Railways DB
http://www.bahn.de/p/view/buchung/auskunft/zugradar.shtml (http://www.bahn.de/p/view/buchung/auskunft/zugradar.shtml) (also in English)
or
http://www.zugfinder.de/ (http://www.zugfinder.de/) (includes freight trains)
These shows the actual position of all trains in Germany.
Some years ago Lufthansa operated trains between various major cities and Frankfurt Airport which also had LH flight numbers.
Look for the "ET 403 Lufthansa Airport Express"
These where painted in Lufthansa livery, personal had Lufthansa uniforms and you could check in on the train.
But that is history.
Quote222222;KF183 x ;22222222; 0.00000; 0.00000; 6475; 0.0; 0.0;2014-02-10 13:58:07;13:58:07; 6;000.0; 0.0;*-;T6 ; ;1531; ;
Mil?! :-\
