Mode-S Software => PlanePlotter => Topic started by: alpey on November 28, 2013, 11:45:36 AM
Hi All
I calibrated extracted charts from the site :
http://www.eurocontrol.int/articles/cartography-support
from 01H until 11H (no 12 and 13).
Each map is divided (S to N) into 2 parts with overlap, UK in 3 parts.
IMPORTANT :
These ERC (EUROCONTROL Regional Charts) are based on EAD data and have been calibrated from an updated 25 July 2013, only the Upper airspace is available.
These maps, Lambert Conformal Conic - Standard projection type, should not be re-oriented and you must select the following :
Options ---> Map calibration ---> Second order polynomial fit
If not the position of the aircraft or GPX data will be totally wrong.
All maps (PNG with CLB) are available, if you are interested sent me a message with you E-mail
Best regards
Alain Peyrat (Alpey)
pm sent looks good!! ;D
