Mode-S Receivers => Kinetic's SBS-1 => Topic started by: charliebrown on December 13, 2013, 03:11:20 PM
Hi Guys
I'm running an SBS1-er with PP, FD and AD Lite.
I have found that with my setup that I can no longer download photo images directly to the BaseStation Aircraft Details window from Jetphotos.com. :(
Does any Forum member have a a working XSL lookup for Jetphotos that will work in my setup ?
My present lookup code that is not working is:
<td width="200">
<a href="http://www.jetphotos.net/showphotos.php?offset=0&where=search|-2|-2|-2|-2|{//regdata/registration}|15|1|||||||-2|-2|-2|-2|||15|1||-2|-2||||reg|1||||||-2|||1|||||||" target="new">
<span class="entrycaption2">Jetphotos.net: <xsl:apply-templates select="//regdata/registration"/></span></a>
</td>
Charlie
I have the same code as you and it is also not working for me from Jetphotos, maybe they have changed something at their end.
