when i try install active display on windows 8 i get this error
ERROR DETAILS
Following errors were detected during this operation.
* [17/05/2014 15:27:36] System.ArgumentException
- Value does not fall within the expected range.
- Source: mscorlib
- Stack trace:
at System.Deployment.Internal.Isolation.IDefinitionAppId.EnumAppPath()
at System.ActivationContext.CreateFromNameAndManifests(ApplicationIdentity applicationIdentity, String[] manifestPaths)
at System.ActivationContext.CreatePartialActivationContext(ApplicationIdentity identity, String[] manifestPaths)
at System.Deployment.Application.ApplicationActivator.DownloadApplication(SubscriptionState subState, ActivationDescription actDesc, Int64 transactionId, TempDirectory& downloadTemp)
at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
- Source: mscorlib
- Stack trace:
COMPONENT STORE TRANSACTION DETAILS
No transaction information is available.
Did you download the 64 bit version to a temp folder and extract the files before running Setup?
i extracted it on my c drive then tried and same thing
It looks like a failed install for some reason.
I would eliminate all of the attempted install and try again.
But where AD components are in Windows 8 is beyond me as I don't have a Win 8 PC here.
You could try contacting Gary's daughter at GAS who, I'm told, is going to support AD.
do we know how to contact his daughter
Try:
ADLicensing@gatwickaviationsociety.org.uk
