Mode-S Receivers => Kinetic's SBS-3 => Topic started by: charmed on August 13, 2015, 02:55:08 PM
Title: Unable to get ethernet working sbs-3
Post by: charmed on August 13, 2015, 02:55:08 PM
I'll try over here as nobody seems alive over on the kinetic forums.
Hi, try as I might I can't get ethernet working. As far as I know I have everything set correctly and yet no joy. My router is set as 192.168.0.1 so I've set the non volatile memory to 192.168.0.170 (well within range) and the gateway as 192.168.0.1. Hardware settings is the same and both port settings are 10001. DHCP address is 192.168.0.1 on the router.
I then connect the ethernet cable, switch to data source, use network and nothing. My router does not see the sbs-3 and I see no way of getting into the sbs-3 to change ip address or even see what it is. I'm on software 1.2.4.185, Firmware Version SBS-3 build 118. Any help gratefully accepted.
Oh yeah, the router is a D-Link DIR-845L.
rick
Title: Re: Unable to get ethernet working sbs-3
Post by: Smudger98 on August 13, 2015, 03:14:37 PM
Hi Rick,
Anmer the usual tech guy and owner here is helping his son move home, so will be in here from time 2 time to-day on a limited access basis - others will no doubt respond in the mean time..
Smudger.
Post by: Chris-G0WTZ on August 13, 2015, 04:02:57 PM
Hi Rick
How are you powering the unit? It needs to be a power supply not a computer!
Did you run it up on USB first?
Post by: IanH on August 13, 2015, 04:28:00 PM
Also try something simple:
Type
ping 192.168.0.170
in a command window (or Windows search box).
You can also try pinging 192,168.0.1 (the router) to see what the response should look like,
If you see responses that say something like "Reply from 192.168.0.171: bytes=32 time<1ms TTL=128" at least you have a connection to the SBS-3.
Post by: charmed on August 13, 2015, 05:56:26 PM
Thanks Chris that was the bit I was missing, the separate power supply.
rick
Post by: Slammer99uk on August 13, 2015, 06:06:48 PM
Just for reference....
Leave the ethernet cable plugged in. Make sure you plug in the red USB to a suitable power source
Plug in the black USB cable, make sure you are using USB as data source (USB shuts down power to ethernet port)
Settings
NVM config:-
Set IP 192.168.0.170
Subnet 255.255.255.0
GW 192.168.0.1
tick SBS-3 as server - port 30003
Settings
Data source - Use Network
Pull the black USB cable and make sure the ethernet light comes on on the SBS-3
You should be good to go. I didnt have to make any changes on my router.
Jerry
Post by: Anmer on August 13, 2015, 06:39:40 PM
Well done everyone.  Looks like I'm redundant.  :)
Post by: Slammer99uk on August 13, 2015, 06:56:54 PM
Quote from: Anmer on August 13, 2015, 06:39:40 PM
Not quite, I just posted something for you to look at for me :)
Jerry
