Hex Codes and Registrations => Civilian Aircraft => Topic started by: Anmer on February 19, 2016, 07:57:47 PM
Heading south east towards The Channel Islands, flight ID N4446N.
The FAA database says the the certificate is expired for a Boeing Stearman built in 1942. FlightAware shows it as STEARMAN PT-17 Kaydet.
Be interesting to know if this is correct?
FL170 and 250 knots not likely to be a Boeing Stearman.
http://sss.airliners.net/photo/Boeing-N2S-3-Kaydet/1421399/L/
Went into Jersey. Suggest a single/twin turbo prop?
All will be revealed before too long but clearly not known at the moment.
Appears to be N4446M and should be A55CAF
PA34
http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=4446M
That makes sense looking at this:
CFB to Jersey
https://flightaware.com/live/flight/N4446M
