Mode-S Receivers => DVB-T Dongles and Self-Assembly Receivers => Topic started by: camallison on May 22, 2016, 06:04:22 PM
Title: RTL1090 Scope window
Post by: camallison on May 22, 2016, 06:04:22 PM
Whenever I start an instance of RTL1090 and open up the Scope tab, the view is centred around Hamburg.  Is it possible to set this to centre around a location that I specify?
Colin
Title: Re: RTL1090 Scope window
Post by: Triple7 on May 22, 2016, 07:20:17 PM
From the information I found, this might help:
Entry of a Home Position (optionally for port 30003 messages only)
The home position can be entered in the [CONFIG] dialog. Entry of a home
position accelerates aircraft position finding. Just copy your entry from
PlanePlotter into the fields of the Config dialog.
The use of the home position can be disabled, e.g. for mobile use,
by unchecking the [USE] box.
The config button is on the main screen, see image below.
I don't use this program but the following might give you a bit more help (and is where I copied the above from):
http://rtl1090.web99.de/homepage/index.php?way=1&site=READOUT&DERNAME=Manual&dm=rtl1090&USER=rtl1090&goto=1&XURL=rtl1090&WB=1&EXTRAX=X&PIDX=102385#2.1%20Command%20line%20parameters
Post by: camallison on May 23, 2016, 09:31:32 AM
Thanks for the prompt response and solution - I had the [USE] box checked.  Uncheck and solved!
Colin
