Mode-S Software => ModeSMixer & ModeSDeco => Topic started by: tekmanoid on July 19, 2016, 10:53:34 AM
Title: using two dongles - acarsdeco strange behaviour
Post by: tekmanoid on July 19, 2016, 10:53:34 AM
Has anyone else experienced weird behaviour with acarsdeco and dump1090 running simultaneously on the same linux box (with two RTL dongles of course)
I have re-programmed the EEPROM of the second dongle with a different serial number.
When dump1090 and acarsdeco are running with each dongle I notice that the acars decoder basically stops decoding (may get only occasional hits, although there are lots of acars-squitters)
Thanks for any help!
Alex
Title: Re: using two dongles - acarsdeco strange behaviour
Post by: Anmer on July 19, 2016, 12:33:08 PM
Is the RPi getting sufficient power for itself plus two DVB-T SDRs?
Post by: tekmanoid on July 19, 2016, 02:02:27 PM
I am using an old HP Thinclient
(http://images.harlander.com/artikel/1000x1000/computer-pc-systeme-hp-t5730-.jpg)
Since the dongles draw ~ 150 mA at most each, while the USB specs are 500 mA it just seems strange it should be a power problem...
Alex
Post by: Anmer on July 19, 2016, 02:21:09 PM
Quote from: tekmanoid on July 19, 2016, 02:02:27 PM
Sorry, I thought you were using an RPi.
Post by: Radio2.0 on August 07, 2016, 12:55:37 PM
I use an HP Micro Server with 2 ADSB Dongle + 2 für Acarsdeco2 and it works ok. The Server run still on 100%.  :-[
