Miscellaneous => Other Topics => Antennas => Topic started by: yarmouthshipping on May 06, 2012, 02:44:55 AM
Title: Homebrew aerial
Post by: yarmouthshipping on May 06, 2012, 02:44:55 AM
Is there an easier homebrew than the one shown ?? if not, the coils do they twist slightly up or are they flat?
Simon
Title: Re: Homebrew aerial
Post by: Anmer on May 06, 2012, 07:46:45 AM
Hi Simon
Which one "shown" where?
Post by: yarmouthshipping on May 06, 2012, 02:29:33 PM
Sorry one shown in a post in this section of the forum http://www.tech-software.net/1090_ant_02.JPG (http://www.tech-software.net/1090_ant_02.JPG)
Post by: Truetrack on May 06, 2012, 05:21:48 PM
Hi Simon
no, there is nothing more simple to that proven design
Frankly you have to stick only with the coax-connector or your chioce,
the disc performing as a ground plane,
and the length of some copper wire.
There is only one turn each which may be twisted around some
and when the ends meet just later pulled apart a bit.
The exact distance between the two coils are not easy to hit,
some people had cut in between and soldered a piece between the coils.
All the rest is for fixing and weather proofing and may be any plastic material
(which has no hidden iron powder within, as some gutter pipe do)
Give it a try
Post by: yarmouthshipping on May 06, 2012, 05:42:34 PM
Hi Klaus
Thanks for that i will have a go, but do you definitely need 50mm pipe would 32mm do or even 20mm
the thing that stumps me is the collars to wedge the 2 lengths of pipe to the disc of aluminium plate
Simon
Post by: shakysen on May 06, 2012, 05:51:56 PM
Hi Simon. Have built two in the last couple of months. Only my opinion! they  pull in better then radar-100 Only concern is supporting them in 50 -60 mph winds.
But I will overcome it. Very easy to build
        Billko
Post by: Truetrack on May 06, 2012, 07:20:20 PM
Quote from: yarmouthshipping on May 06, 2012, 05:42:34 PM
Simon
The dims for the cover are not at all critical, and as Billko put it the windload might be a factor to be considered.
32mm should certainly be ok provided you find a way of  getting/keeping the copper rod more or less in center
at least not touching the piping ( e.g. styrofoam wafers or such  )
BTW it must not be aluminum for the disc, copper might to heavy, tin can mat'l needs protection laquer
against corrosion.
Post by: yarmouthshipping on May 06, 2012, 08:12:27 PM
Ok then i will have a go and see what happens thanks for all the advice
Post by: Truetrack on May 06, 2012, 10:53:46 PM
Here some background info
these measures are dependent of frequency respective wavelength
and here 1/4 WL or multiple thereof.
And that stand for those two single turn coils also.
The Dia of 20mm or ( ~ 22mm centre to centre multiplied by Pi  3.14 ) should represent
6.9 cm which again is 1/4 WL !
Myself found it is best to mark off the different portion of length,
continue with the sharp bends and finally form the single 20mm turns.
I had used 2mm iron welding rod for indoor attic use, maybe 3mm hard copper rod
is harder to bend.
Post by: yarmouthshipping on May 07, 2012, 06:24:52 PM
Quote from: shakysen on May 06, 2012, 05:51:56 PM
        Billko
Where did you get the bits from i tried the usual subjects bq hb wilkes
they had pipe and thats it
Simon
Post by: shakysen on May 07, 2012, 07:40:16 PM
Hi Simon. Have you any wire coathangers?. They work fine you may have to scrape off the coating to solder it to the socket. I have used wire of hangers for all kinds of antennas. and hairpin matches for my yagis. Another way is twin and earth take the solid earth wire and use that (30 amp)
        Billko
Post by: yarmouthshipping on May 07, 2012, 08:00:24 PM
Sorry meant the pipe end caps and collars
Post by: shakysen on May 07, 2012, 08:29:18 PM
Hi Simon I got mine from Koi center I use them on my filters .50mm £1.50 for end caps £2.50 mtr for pipe
                                                           Billko
Post by: yarmouthshipping on May 07, 2012, 08:38:48 PM
No wonder i cant find the bits never mind
Post by: shakysen on May 07, 2012, 08:46:15 PM
Hi again Simon.You have just solved the windage problem for me. Not going rooting around now.Tomorrow will do Ithink I have some thick walled pressure pipe 25 mm
and a25mm flange will let you know later if it works
        Billko
Post by: yarmouthshipping on May 07, 2012, 09:06:12 PM
got mine from screwfix 2mtrs for £1.47
Post by: Truetrack on May 07, 2012, 10:13:46 PM
Quote from: shakysen on May 07, 2012, 07:40:16 PM
        Billko
Hi all - a bit OT but it fits to homebrew !
re wire coathanger, I love 'em
these are my favourite dispensable travel items
good for vertical dipoles, GP , Triple(quadruple) legs,
all easily exact tailored to your freq
all you need are a few coathangers
one or two coax chassis-sockets of your choice (4-hole)
a plier for cutting and sharp bending
a length of customized coax cable
and that's about it.
everyone goes SMA, but for these purposes I prefer the Bayonet-Neill-Concelmann = BNC
no screwing here! Just quick connect/disconnect.
In practice I had some 3 cms of 1.5mm solid copper soldered into the chassis socket
and clamp the coat wire to it and cut to length. I do not know how you call it,
a metal clamp with 2 screws to connect two ends of wire e.g. Mains, or in switching boards.
A little bent hook ontop enables you
to hang it most everywhere e.g. hotelroom-window shades or what not.
Into the 4-holes you can hook  the lower section of a dipol.
with clever bending you can form radials to be horizontal as in GP, or drooping 45 degrees
downwards, holding indoors simply by gravity.
It works - the contact betwween the metal is good enough for VHF/UHF Comms .
almost forgot that;
Formula (short Version)
75/freq(Mhz)= 1/4 wavelength (meter)
have fun experimenting
Post by: yarmouthshipping on May 07, 2012, 10:24:43 PM
Cheers Klaus
Post by: yarmouthshipping on May 08, 2012, 09:06:10 PM
how did you get on i cant get any reception thru mine i have checked and checked think i will save for manufactured one
Post by: shakysen on May 09, 2012, 11:29:25 AM
Hi Klaus.Take a look at this site (find one in english) http://f5ann.pagesperso-orange.fr/AntenneStrip-line1090MHz/index.html
                                                   Billko
Post by: Truetrack on May 09, 2012, 02:31:57 PM
tks, I had that french site previously bookmarked.
Have a look at AMOS-5
another and different approach this Franklin-centre feed type of antenna
BTW re etched PCB for antenna elements
one Juan Gelb of Brasile posted somewhere fotos
a/ of his homebrew collinear and
b/ a dismantled GP1090 this is also a slim PCB etched with 4 sections if I remember right.
sorry cant find the link anymore
Post by: gutopohl on September 28, 2012, 05:39:07 PM
Hi!!
Does someone know how to connect two 50 ohm antennas in one receiver and keep the 50 ohm?
My idea is put the demo antenna that's comes with microAdsb and my home brew high gain collinear antenna working together.
Post by: Truetrack on September 28, 2012, 10:29:19 PM
well, when homebrewing at it, you could consider preparing a 1/4wavecoax-section as transformer.
with both antennas combined and such connected in parallel the resulting impedance is only 25 Ohms.
You can step this up by using a short length (quarterwavelength incl. velocity factor) of 100-Ohm Coax.
A bit tricky 1/4 WL = 6.88 cms , velocityfactor depending on cable 0.8 to .86 makes it only 5.5 to 5.9 cms length.
Formula
square root of (25 x 100) = 50 Ohms out.
So for practical reason use a T-Piece, center connected to Transforming section and
continue into your downleading coax cable.
so far the theory, question remains
are the different qualities of your antennas so prominent that the effort is justified
and not possibly spoiled by other factors ?
Post by: gutopohl on October 01, 2012, 06:14:54 PM
Hi Truetrack.
Thanks for your replay.
Let me try to explain what's happening.
A few weeks ago I built this project: http://www.wardrivingonline.com/equipment/antenna/omnicolliner-antenna-design.htm
I changed the length of 1/4 to 'feet' 1090 mHz.
The results are much better then demo antenna that's comes with microadsb but now I got a huge Doughnut affect.
Guto.
Post by: Truetrack on October 01, 2012, 10:46:56 PM
Yes that is plausible then.
All those multisectioned collinears whether industrially manufactured or homebrew
have these effect. They just focus the ring of lobe to the horizon, thus flattening it
like a doughnut.
One may use less elements resulting in less horizontal gain to a certain extent as a compromise,
and possibly use of expensive preamp and T-injection of power instead.
regards
Post by: gutopohl on October 02, 2012, 07:56:51 PM
Thanks Truetrack.
I will try to build the coax transformer using your formula. Right now buy an expensive preamp is out of context.
Let see what will happens!
Thanks again!
Guto.
Post by: dongle on October 26, 2012, 04:40:07 PM
You can make a pre-amp for about £4.
Take care how you feed in the power to it and make sure you provide a capacitor of maybe 100pf between the collector of the transistor and the input line to your receiver, else you won't do the RX any good at all.
Here is a really cheap one:
http://www.lll.lu/~edward/edward/adsb/preamp/ADSBpremap.html
Then you can buy this kit for about a tenner plus £2 postage:
http://www.g4ddk.com/SPFAMP.pdf
Here is another simple design:
http://users.belgacom.net/hamradio/schemas/preamp_HF_VHF_UHF_SHF_wideband_MAR6.htm
Post by: JohnOCFII on May 14, 2013, 07:21:48 PM
Quote from: Truetrack on May 06, 2012, 05:21:48 PM
Are there any additional drawings or photographs of this simple 1090 MHz antenna?  I'd like to see the proper way to create the little 20 mm turns in the copper wire.  Are the turns mostly horizontal, or mostly vertical?
I see this additional drawing of the two caps butted together.
http://www.tech-software.net/endcaps.bmp
Is it correct that the aluminum plate goes between the two caps?  Is the aluminum plate electrically attached to anything, such as the external connector on the Coax connector?
Also, the first drawing shows the lower tube section as 600mm.  Does the length of that section matter?  It seems the actual antenna is above that in the other section, and this tube only houses the coax you would connect to the antenna.  I have no problem creating that length - just curious as to why there is a stated size.
Thanks!
John
Post by: IanH on May 14, 2013, 08:08:08 PM
The member known as "shakysen" is your man. He knows how to make these.
Post by: shakysen on May 14, 2013, 08:23:11 PM
Hi John. I use 20mm waste pipe,mark your bottom section with a bit of tape bend the wire Round the pipe.mark middle section and tape off same again with pipe. just pull each coil up so not touching. the vertical part must not touch the disk. They work very well 130-150nm, East,100-120nm North, 100nm South. An mine is poor in the West 90nm. Mine Are indoors
        Regards Shaky
Post by: JohnOCFII on May 15, 2013, 04:09:33 AM
Thanks Shaky!
I noodled around and also found the following useful information:
There are two sections at the page below discussing antennas, including a photo of his attempt at a ground plane antenna for ADS-B:
http://www.sprut.de/electronic/pic/projekte/adsb/adsb_en.html
I also found detailed instructions for a similar ground plane ADS-B antenna linked from here under "Your first ADSB Antenna":
http://www.atouk.com/wordpress/?page_id=237
John
Post by: Saudistu on May 18, 2013, 08:23:18 AM
Quote from: dongle on October 26, 2012, 04:40:07 PM
If anyone has had a go at making and using one of these can they please post the results, as in does it give a noticeable increase in range ? Thanks for any help.
