Mode-S Software => PlanePlotter => Topic started by: chrisellio on September 13, 2017, 03:34:23 PM
Title: Issue with Country Flags
Post by: chrisellio on September 13, 2017, 03:34:23 PM
I have recently installed and are running the country flags. The problem I am having is that certain countries are not showing a flag, in particular G, N, A6 and one or two others. Can anyone point me in the right direction please
Title: Re: Issue with Country Flags
Post by: Roadrunner on September 13, 2017, 03:49:55 PM
Hi There,
All the bmp files in the BMP Flags folder should not have gaps between the words, for example United Kingdom should read United_Kingdom.bmp, or for USA United_States.bmp or UAE should be United_Arab_Emerates.bmp etc, also the entries for these countries in the Countries.dat file should read the same (The left hand side of the list shows the entry as it appears in the BaseStation.sqb, the next area is the hex codes grouping and on the right is the corresponding .bmp file example rows below. Note Countries dat should be opened and amended using Notepad rather than word.
United Arab Emirates Mil_1214=100010010110000000101100,24,United_Arab_Emirates_Mil.bmp
Hope I am not trying to teach you to suck eggs but rather spell it out than leave something out.
Best of Luck
Post by: Triple7 on September 13, 2017, 04:54:19 PM
The above post refers to files associated with basestation, this is the PlanePlottter section, so I assume the OP wants guidance on the setting up country flags for use with PP.
There's a guide on using country flags in PP here:
https://radarspotting.com/forum/index.php?action=tpmod;dl=item99
Please let me know if there is anything missing from that guide and I will amend it.
Post by: Keef on September 13, 2017, 06:33:27 PM
Hi Tim,
The links in your guide refer to Bones' old website, it might be worth updating them to, for example:
http://woodair.net/sbs/Utilities/Kinetic_Utilities4_Bitmaps.htm (http://woodair.net/sbs/Utilities/Kinetic_Utilities4_Bitmaps.htm)
The guide is one I've used and is much appreciated  :)
Keef.
Post by: chrisellio on September 13, 2017, 07:25:56 PM
Thanks for your help guys its easy when you know how
Post by: Triple7 on September 13, 2017, 07:40:36 PM
Quote from: Keef on September 13, 2017, 06:33:27 PM
The links in your guide refer to Bones' old website, it might be worth updating them.
Hi Keef,
Good spot thanks, I wrote that several years ago, so I will amend it and get Mike to upload a new version with corrected links.
Post by: chrisellio on September 17, 2017, 05:59:29 PM
I appear to be missing the entry in BSFlags for Serbia, can anyone help please
Post by: Triple7 on September 18, 2017, 07:54:03 AM
4C0000 4C7FFF
Post by: chrisellio on September 19, 2017, 06:39:41 AM
Thanks very much, whilst adding that to my BSFlags I noticed that I haven't got Serbia Mil either
Post by: Triple7 on September 19, 2017, 08:43:48 AM
Hmm interesting. I have the flag but not the hex range. But then as I don't have any Serbian Mil in my SQB, it won't really matter.
Post by: Keef on September 19, 2017, 03:08:52 PM
I might be wrong but if I'm reading my Basestation countries.dat file correctly Serbia Mil only has one value, so the 'range' would be:
4C0155 - 4C0155.
Post by: Triple7 on September 19, 2017, 05:35:01 PM
Thanks Keef,
I used the sticky thread here:
https://radarspotting.com/forum/index.php/topic,7159.msg33736.html#msg33736
to remind me how to read the countries.dat file and I agree, there seems to be only one code:
4C0155 a Yak40 reg 71505 of the Serbian Flight Inspection
