Mode-S Software => PlanePlotter => Topic started by: Anmer on September 18, 2017, 07:36:12 AM
Title: PlanePlotter Version 6.4.6.1 Released
Post by: Anmer on September 18, 2017, 07:36:12 AM
Message from Bev at COAA:
PlanePlotter version 6.4.6.1 is on the web site today.
http://www.coaa.co.uk/planeplotter6_4_6_1.exe
I have released this a little sooner that I would have done but in the light of recent debate about receiver types, this version contains changes that might help users better to judge their receiver's multilateration performance.
---Usual boilerplate---
You may need to exercise your browser Refresh function to force it to show you the new version of the PlanePlotter web page. If you post a message complaining that the web site is still pointing to an earlier version, you pay a forfeit!
You can install the new version over the old one but you *must* close/exit PlanePlotter before installing the new one. Your settings will be preserved. Nic's installer will warn you if PlanePlotter is still running when you try to install the new version.
If you have a version-specific firewall (eg Zone Alarm), you may have to reassure it that the new version is permitted to access the Internet. Be aware that an increasing number of security systems treat any new file as a threat without any justification except that it is new. Please don't write to me about it; write to your security system provider and ask them to make their program smarter.
If you have an installation of PlanePlotter running under Linux/Wine, this installer may not run. In that case (only), please download :
http://www.coaa.co.uk/planeplotter6_4_6_1.zip
and unzip the files into the existing PlanePlotter application directory. Note that this will only work if PlanePlotter is already installed under Wine as it only contains the new executable and not all the other files that are required to run the program.
New in version 6.4.6.1
Purge aircraft accelerator key
Alt-p now purges aircraft from the current displays. They will reappear as soon as new data is received off-air or by sharing.
Auto repaint improvement
If enabled, the automatic repainting of maps or outlines after dragging or zooming will now generally use the same style as the display being repainted. There are still some lacunas where the display came from a saved map within the Quick chart since the origin of the maps is not stored. Otherwise, the style (map type, selected outlines, terrain addition etc.) should remain the same after a repaint.
Identifiable hyperbolae
If you perform a manual Mlat and enable the display of the resulting curves that generate the fix, this version now shows any hyperbolae that were based on raw data from your own receiver, will be in yellow. All other hyperbolae remain in blue as before. The GS marker for your own location is also plotted in yellow (blue for other contributing GS). In addition the Mlat report dialog now shows the count of "own" hyperbolae in addition to the report of the total number of hyperbolae in the fix. I hope these three additions will help users to judge the performance of their own receiver when performing Mlats. If all the curves are blue, then your receiver has not made any contribution to the fix. If many curves are in yellow, then your own receiver is making a useful contribution to the fix.
Enjoy!
