Mode-S Software => PlanePlotter => Topic started by: Anmer on October 04, 2017, 02:37:47 PM
Message from Bev at COAA:
PlanePlotter version 6.4.6.2 is on the web site today.
Download (http://www.coaa.co.uk/planeplotter.htm#download)
Among other things, this release fixes the outline auto-repaint that was broken in the last release. It also accommodates the new Airframes.org log-in requirement.
If you have been involved in testing this release, please re-install this version as it may contain extra features that were not in the test versions.
---Usual boilerplate---
You may need to exercise your browser Refresh function to force it to show you the new version of the PlanePlotter web page. If you post a message complaining that the web site is still pointing to an earlier version, you pay a forfeit!
You can install the new version over the old one but you *must* close/exit PlanePlotter before installing the new one. Your settings will be preserved.
Nic's installer will warn you if PlanePlotter is still running when you try to install the new version.
If you have a version-specific firewall (eg Zone Alarm), you may have to reassure it that the new version is permitted to access the Internet. Be aware that an increasing number of security systems treat any new file as a threat without any justification except that it is new. Please don't write to me about it; write to your security system provider and ask them to make their program smarter.
If you have an installation of PlanePlotter running under Linux/Wine, this installer may not run. In that case (only), please download : http://www.coaa.co.uk/planeplotter6_4_6_2.zip and unzip the files into the existing PlanePlotter application directory. Note that this will only work if PlanePlotter is already installed under Wine as it only contains the new executable and not all the other files (SQB etc.) that are required to run the program.
New in version 6.4.6.2
Outline auto repaint
The auto-repaint feature for charts and outlines was introduced a couple of releases ago. Unfortunately, the last release stopped the auto-repaint of outlines from working correctly, although the auto repaint of charts continued to work as intended. This release restores the operation of the outline auto repaint.
New OLE/COM function
If you control PlanePlotter from a script, you can now set and reset the "Interested" flag on any current aircraft. The new OLE/COM function "SetPlaneInterestedByHex" takes two arguments : the aircraft hex code and a numeric value which should be "0" to unset the "Interested" flag for that aircraft, or "1" to set the flag.
New Airframes.org login
This release restores the operation of the LookUp button in the Airrep dialog. Note that if you have not already done so, you must first visit http://www.airframes.org/signup to create an account. It is free to do so. Then having got a username and password for www.airframes.org, select PlanePlotter..Options..Airfames login (at the bottom of the menu pulldown) and carefully enter those details into the dialog box and click OK.
Once you have done that, then initiating a look up of an aircraft's details will open the Airframes login page, it will put in your details, it will press the button, and then in the familiar query box, it will put in the details of the wanted aircraft and press the button- all while you watch. It takes a few seconds longer than it did before, but the functionality is restored. The details in the results page are automatically transferred to PlanePlotter. Note that this functionality uses API features that are unique to Windows Internet Explorer. if you are pathologically opposed to having IE on your machine, this function is not available to you.
Airline prefix conversion
Depending on the source of the data, flight numbers may be preceded by an IATA airline code or by an ICAO code. Currently, PlanePlotter seeks to convert the former to the latter when the data is received in a binary message from one of the Inmarsat satellites. In this release, the airline prefix is also converted for plain language messages via Inmarsat or via VHF ACARS. Accordingly it seeks to translate a very much large number of possible prefixes and to that end, it now does the conversion using an SQB file called iataicao.sqb which is included in this release. I have used publicly available information to compile the database but it might include errors or omissions. If so, you can edit the SQB database yourself using any of the SQLite editors to correct or insert information. Bringing more of the flight numbers into the same format should reduce the number of times that PP identifies reports from different sources (that use different flight number formats) as bein! g different aircraft.
There will still be incongruities where, for example, the ICAO flight number is listed as ABC0123 but the IATA flight number is listed as AB123. PlanePlotter cannot guess if and how many leading zeroes might be required to make them match - particularly if the IATA version is received first.
It does not attempt to convert flight numbers in HFDL messages as they are unpredictably either IATA or ICAO format and, because some flight numbers have letters after the prefix, it is not possible to tell which is which algorithmically.
Enjoy!
