I currently have my SBS-1 running on a Windows Vista set up and my intention is to instal/re-instal it on a another computer running Windows7. I would be grateful for any suggestions on the simplest way to achieve my aim.
Regards-
G.B.
It depends on your existing folder location. Is it in a Program Files folder?
If not, I'd copy your current BaseStation folder, sub-folders ad files to an external data source, such as a USB stick.
On the new PC, create a new folder "Kinetic" and copy the BaseStation folder, sub-folder and files to it.
Plug in your SBS and double click the BaseStation.exe file in the new folder location. Does BaseStation run OK?
Thank you for your reply Mike- From memory I think my BaseStation folder resides in the beloved by many Virtual Store :-\.Does this alter your advice in any way?
Regards-
G.B.
If you have a Windows default install, your "active" BaseStation.sqb file will be in the Virtual Store and you will need to copy this one.
I'm away from home without a PC (using Chromebook) so can't check if the ini file is there too.
OK Mike, this transfer is on my list of jobs to do when I get round to it!
Give my love to Texas and my regards to Mr. Trump should you happen to bump into him ;)
regards-
G.B.
Just read your thread
If your old PC BS used the Virtual Store
you will find these 4 files as the current ones
Basestation.INI
Basestation.SQB
Basestationreporter.INI
Reference.SQB
all with a Datetime Stamp when you last run BS oder Reporter
while whereever Basestation and subfolders was placed
these 4 should be older and out of date.
If you are now not using Virtual store you may copy/replace by the current ones
just into where the complete BS Prog is located .
Hope this helps too
I am obliged to you Truetrack for that information
G.B.
A further update on this for those who maybe interested I decided, before Microsoft finally pulled the plug,to take advantage of the free upgrade from Windows 7 to Windows 10.I have to say that this upgrade was simple and trouble free and relatively fast,about 3 1/2 hours from initial click o having Win 10 running and so far so good.
So the next question is when it comes to moving my SBS 1 from the Vista computer to the Win 10 one are there any `nasties`waiting to ambush me?
G.B.
Quote from: Graham Bell on December 26, 2017, 03:02:21 PM
The dreaded Virtual Store. Steer clear.
Thanks Mike-Noted! :-\
Regards-
G.B.
I now have my SBS1 up and running on a Windows 10 setup.I opted for a new instal and all seems well with one exception I am unable to get the Operators Flag column in the aircraft list to display any information at all.From memory do I have to delve into the ini file and fine tune?
Regards-
G.B.
I'd use Acarslogger's excellent ALC:
http://woodair.net/sbs/Utilities/Kinetic_Utilities5_Utils.htm
Thank you Mike, will give that a go.
Regards-
G.B.
On this ALC program there is no dedicated Windows 10 tab to click on,does this work with this OS?
Regards-
G.B
Shows its age Graham.
If you installed BaseStation in the default folder location, select Standard Vista Install. i.e you allowed Windows to use the dreaded Virtusl Store.
Mike- Acting on your suggestion it is now installed in C:/Kinectic/Basestation so I assume I opt for the non standard instal option?
Regards-
G.B.
Yes, that looks good.
I,m obliged for your input Mike
Regards-
G.B.
