Mode-S Software => PlanePlotter => Topic started by: gcopter1 on March 25, 2018, 08:39:19 PM
Title: Using Jordan's Outline Maker
Post by: gcopter1 on March 25, 2018, 08:39:19 PM
Probably not related to the forum but, been asking elsewhere for the past couple of days and searching all over with no results.
After a long time away from the hobby, got myself a new ads-b recvr.
Downloaded and got Plane Plotter to run. Now, I wish to add airport outlines to my chart.
Found Jordan's Outline Maker, got my coordinates and copied them. Pasted them in the charts folder but the airport outline won't display.
Kept searching and looking around and found a post where someone wrote that the saved .out file has to be named AND something put in squiggly lines/brackets in order for the file to work.
Does someone knows the exact procedure?
Title: Re: Using Jordan's Outline Maker
Post by: Triple7 on March 25, 2018, 08:57:31 PM
Not sure what the reference to squiggly lines is all about but if your outline files are saved as .out files and pasted into the 'chart files' sub folder in the PlanePlotter folder and - important - you have correctly defined that folder as the place for PP to look for charts, they should display.
Options>>Directories>>PP Chart Files
Navigate to the folder containing your .out files and they should show.
Post by: Anmer on March 25, 2018, 09:35:06 PM
This may help:
https://radarspotting.com/forum/index.php?action=tpmod;dl=item12
Post by: gcopter1 on March 26, 2018, 12:19:04 AM
Thanks Anmer. This is what I was referring to;
https://books.google.com/books?id=XJ5pAwAAQBAJ&pg=PA116&lpg=PA116&dq=outlines+squiggly+lines+brackets+plane+plotter&source=bl&ots=9u4E2c7D8d&sig=q4pRX1rHI9VFrHqQmR6dOD1IP9M&hl=en&sa=X&ved=2ahUKEwjdwfiYy4jaAhVRy1MKHfZnAuAQ6AEwAHoECAYQAQ#v=onepage&q&f=false
Post by: gcopter1 on March 26, 2018, 12:25:51 AM
Quote from: Triple7 on March 25, 2018, 08:57:31 PM
Thank you as well.
Post by: Anmer on March 26, 2018, 08:26:22 AM
The "squiggly" lines enclose a name for the outline.  It can be anything you wish.  But it's the file name that's recognised by the BaseStation software - "filename.out".
I'm away from home at the moment so can't check PlanePlotter.  Maybed use the PlanePlotter Help to read up how it handles .out files.
