Mode-S Software => PlanePlotter => Topic started by: gcopter1 on May 04, 2018, 03:23:39 AM
Title: What are these?
Post by: gcopter1 on May 04, 2018, 03:23:39 AM
What are these circles?
Ever since becoming a GS, I've must've stumbled across a setting that is doing this. I believe, it was, in chart options, enable and fill.
What is it used for?
How to interpret it?
Title: Re: What are these?
Post by: Triple7 on May 04, 2018, 08:38:13 AM
You are correct they come from Options>>Chart>>Circle sharers>>Enable or circle fill and are described in the help file thus:
This option draws a circle around the location of each sharer that has reported the designated aircraft in the last minute or two, if the sharers' locations are known. The feature is primarily intended to help in locating aircraft that are not transmitting their positions. The circle is intended to show the area within which the designated aircraft may be expected to lie and its size depends on the reported height of the aircraft and also on the characteristics of each user's reception system.
Plus some more details on operation. Search for 'circle sharers' in the help file.
Post by: gcopter1 on May 11, 2018, 10:52:20 PM
Thanks!
