Mode-S Receivers => Other Mode-S Receivers => Topic started by: glenn68 on May 12, 2018, 01:01:32 AM
Title: Flightaaware PI aware questions
Post by: glenn68 on May 12, 2018, 01:01:32 AM
I just purchased this from Amazon since I already have the other Flightaware required parts.
https://www.amazon.com/gp/product/B01GT4PY42/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Now I am been around for a while with feeding Flightaware through Plane Plotter and working with all the command line programs on windows.
On Rasberry Pi, Can more than one dongle be used on a single Pi? and run seperate programs on the same Pi?
Now I am not versed in Lynix or Rasberry Pi.
Thanks in advance,
Glenn
Title: Re: Flightaaware PI aware questions
Post by: Anmer on May 12, 2018, 07:59:39 AM
I've not had personal experience of running more than one DVB-T device on a single RPi.
But if it helps, you can run PlanePlotter "off" PiAware.
Setup your PiAware feed as explained on the FlightAware site:
https://flightaware.com/adsb/piaware/build
Then run PP on your Windows machine and setup:
Options-> I/O Settings-> Mode-S/ADS-B-> RTL >RPI+Dump1090
Options-> Mode-S Receiver-> RTL dongle RPi Dump1090-> Setup TCP Client-> IP Address:30005
Where IP Address is the IP Address of the RPi.
Post by: IanH on May 12, 2018, 06:02:43 PM
You don't say what you want to use the other dongle for.
However it is possible to run two dongles on one Pi.
An example is at https://discussions.flightaware.com/t/ads-b-receiver-project-setup-scripts/17807 which enables reception of 1090MHz transmissions on one dongle and 978MHz transmissions on the other.
There is also an example of three dongles receiving ADSB, ACARS and ATC audio: https://hamradioscience.com/adding-ads-b-acars-and-atc-audio-to-planeplotter-using-multiple-rtl2832u-sticks/
Post by: glenn68 on May 13, 2018, 12:43:20 AM
I thought of running the other dongle for acarsdeco2 or DUMP vdl2.
Post by: glenn68 on May 13, 2018, 12:49:37 AM
Anmer,
I have it set up TCP-IP for PP.
