Mode-S Receivers => Kinetic's SBS-3 => Topic started by: airis on June 17, 2018, 10:51:22 AM
Title: New computer, Windows10. SBS-3/ Error message,when trying to feed flightradar24
Post by: airis on June 17, 2018, 10:51:22 AM
My old computer did crash and trying to start feeding to flightradar24 from another computer. I got my SBS3/Basestation working. But cannot get the flightradar24 feeder started. Version 1.0.19-15
I am not good with computers.
I send the settings Anmer did send me when I did send a PM. Old sharing key was OK
I did change in step 4.1 receiver selection from 2 to 3 as I have and SBS-3. Is 2 better even for SBS-3?
5. SBS3 via Network with your Basestation getting data from
FR24 software.
Step 1.1 - Enter your email address (username@domain.tld)
$:abcd@xyz.com
Step 1.2 - If you used to feed FR24 with ADS-B data before enter your sharing key.
If you don't remember your sharing key, please use the retrieval form:
http://feed.flightradar24.com/forgotten_key.php
Otherwise leave this field empty and continue.
$:SharingKey
Verifying sharing key...OK
Step 4.1 - Receiver selection:
1 - DVBT Stick (USB)
2 - SBS1/SBS1er (USB/Network)
3 - SBS3 (USB/Network)
4 - ModeS Beast (USB/Network)
5 - AVR Compatible (DVBT over network, etc)
6 - microADSB (USB/Network)
7 - SBSx via Basestation (localhost:30006)
Enter your receiver type (1-7)$:2   I did change this to 3. Is it ok?
Step 4.2 - Please select connection type:
1 - Network connection
2 - USB directly to this computer
Enter your connection type (1-2)$:1
Step 4.3A - Please enter your receiver's IP address/hostname
$:192.168.X.X
Step 4.3B - Please enter your receiver's data port number
$:10001
Step 5.1 - Would you like to enable RAW data feed on port 30334 (yes/no)$:no
Step 5.2 - Would you like to enable Basestation data feed on port 30003 (yes/no)$:no
Step 5.3 - Would you like to enable SBS/Basestation RAW data feed on port 20072
(yes/no)$:yes
24
Step 6A - Please select desired logfile mode:
0 - Disabled
1 - 48 hour, 24h rotation
2 - 72 hour, 24h rotation
Select logfile mode (0-2)$:2
Saving settings to fr24feed.ini...ERROR Just got an error message here and cannot continue.
Thank you for your help
Title: Re: New computer, Windows10. SBS-3/ Error message,when trying to feed flightradar24
Post by: Anmer on June 17, 2018, 10:56:36 AM
I did reply to your email.
Do you want to share your data direct from your SBS or from BaseStation?
I am sharing from BaseStation and my ini file looks like this (sensitive data removed).
During Setup I chose option 7:
receiver="basestation"
fr24key="sensitive data"
host="localhost:30006"
bs="no"
raw="no"
logmode="0"
mlat="no"
mlat-without-gps="no"
Post by: airis on June 17, 2018, 11:04:50 AM
Thank you for your messages!
From Basestation via USB
In the past similar thing happened, but then I did get the feeder starting easily. It was different back then.
Post by: Anmer on June 17, 2018, 11:20:10 AM
If you want to send data from a running BaseStation to the FR24 receiver you need to set up the feed using Option 7.  The same as I've done.
The BaseStation -> FR24 feed will be over your local network (both running on the same PC).  The SBS can be conencted to the PC by USB.
Post by: airis on June 17, 2018, 11:35:34 AM
Where can I find this?
bs="no"
raw="no"
logmode="0"
mlat="no"
Post by: Anmer on June 17, 2018, 12:20:24 PM
Quote from: airis on June 17, 2018, 11:35:34 AM
When you run the FR24 feed for the first time you are presented with options, including number 7.
If you delete the "fr24feed.ini" file you should start again.
There's a PDF manual that exclains this.
https://repo-feed.flightradar24.com/fr24feed-manual.pdf
Post by: airis on June 17, 2018, 05:08:14 PM
I did read the manual. 2.2.3 Installation
A - Download the latest version Done
B - Extract it This I had not done. After doing this I did get past ERROR.
C - Start it
To start the sharing simply double click on fr24feed.exe!
Did start it and got past the ERROR.
The feeder started working, but could not get connection to the SBS-3 or Basestation.
So I think my settings or ports etc must be wrong somewhere
These should be my present settings
receiver="sbs3usb"
fr24key="xxxxxxxxxxxxx"
bs="no"
raw="no"
baudrate="921600"
logmode="1"
windowmode="0"
mpx="yes"
mlat="no"
Post by: Anmer on June 17, 2018, 05:59:38 PM
Great, some progress.
From where are you getting those settings?
Here is my ini file and the Status window for Setttings.
They're different to yours for Option 7.
fr24key="Removed"
bs="no"
raw="no"
logmode="0"
mlat="no"
Post by: airis on June 18, 2018, 08:27:21 AM
I think those settings were in some file under fr24feed.exe file.
Last night I tried to change it to Option 7. No luck. So I switched off my computer.
When I started my computer this morning and started fr24feed.exe it right away started feeding.  So I think better not do anything more now.
I see version 1.2.3.2
My friend did copy many files from my old computer. There was even an old backup for Basestation reporter. Too bad from 2014. So I got some old data back to my reporter.
I had made a backup in late May, but those are all CSV-files. No backup.bbk file in my memory stick. Is there any way to copy these files to my Basestation Reporter or to the old backup.bbk file?
Post by: Anmer on June 18, 2018, 08:44:48 AM
Quote from: airis on June 18, 2018, 08:27:21 AM
BaseStation Reporter is a file viewer/editor.
The aircraft data that it views is to be found in the BaseStation.sqb file.
You can copy the sqb file but beware.  If you have Windows Vista or later, you may have a default BaseStation install that places the active sqb file in the Virtual Store. The one in the BaseStation folder is what I call a ghost file with no aircraft data.
You need to expose the Virtual Storee and copy the active sqb file.
Post by: airis on June 18, 2018, 09:46:28 AM
Thanks. I see what I can do. I had no idea when making backup to my memory stick it wasn´t ok.
Thank you very much for your time and help.
