Miscellaneous => Other Topics => Antennas => Topic started by: BigRed on June 15, 2012, 09:03:18 AM
Title: Any ideas
Post by: BigRed on June 15, 2012, 09:03:18 AM
Would anyone know if you disconnect a Elad power amp from back of SBS3 and reconnect if you also need to disconnect and reconnect antenna from antenna base like the kinetic pre-amp?
In my case my Elad after doing some maintennace doesnt seem to be recieving as it was....
Also are the blue lights indicative of the pre-amp working as it seems to be the case on my other SBS3???
Thank you.
CAM
Title: Re: Any ideas
Post by: Anmer on June 15, 2012, 09:12:54 AM
I've had my Elad preamp for 6 years and had numerous power disconnects and it always kicks in again without needing to remove and reconnect anything at the antenna end.
In my experience the blue SBS-1/3 lights don't change with or without the preamp but for those with less aircraft it may do.
Post by: Chris-G0WTZ on June 15, 2012, 09:18:12 AM
Cam which antenna are you using?
There can be an issue with the Elad style of amp and some antennas
Post by: BigRed on June 15, 2012, 11:17:15 AM
Hi Chris,
Im using the BSC1105 (Ithink it is) you sent me. Great antenna (almost better then the Moonraker). Im currently using the Elad with it.
Cheers
CAM
