Mode-S Software => PlanePlotter => Topic started by: gcopter1 on December 05, 2018, 02:01:23 AM
I ran across a problem where PP wasn't sharing. Poking around, I manage to screw up the whole thing.
I then decided to download PP again, after running the .exe file, I get the "Failed to create empty document" message.
I read somewhere where cleaning the registry, allowed for running the .exe file all over and start anew.
The post didn't specify the entry that needed to be removed to allow running the .exe file, without getting the error message.
I do want to be able to load the previous settings, so, if you have instructions to clean the registry, bear this in mind.
I'm away from home this week so cannot check my PP install.
However, I'm seeing others reporting a similar issue on other forums.
Maybe check the PP forum?
http://groups.yahoo.com/group/planeplotter/
You're not going to believe this.
This morning I woke up, launched the program and it's working again... ???
The good news it's working again. Maybe a PP server side issue, since fixed.
