February 28, 2021, 03:43:33 AM
Members
  • Total Members: 5894
  • Latest: list83
Stats
  • Total Topics: 12728
  • Online Today: 39
  • Online Ever: 78
  • (January 15, 2021, 06:24:24 AM)
Users Online
Users: 1
Guests: 34
Total: 35
Donations
Donations help with annual costs and keep Radarspotting free of advertising. Thank you.
Latest Post
Links & Files
21st February 2021. Latest Zip file from Chris Alder now available.
If you're looking for a bulk download, we have over 66,000 aircraft silhouettes, profiles and operator logos available in bmp file format, 85x20 pixels. You can find all the Zip files here.
Some of the Latest Additions:
Author Topic: Automated Installation of ModeSMixer2 & ModeSDeco2 on RPi  (Read 1546 times)
Offline abcd567
  • Member
« on: August 19, 2019, 05:48:36 AM »
Easy Installation - Just copy-paste one command to run bash script and it does everything.
Automatic start - systemd service automatically starts it at boot/reboot.
Easy monitoring & control - Provides commands systemctl status, systemctl stop, systemctl start, and systemctl restart.
Easy configuration - Provides a separate config file in simple format, each config item on a separate line.
FOR DETAILED INSTRUCTIONS:
ModeSMixer2:
Does NOT require a dedicated dvbt dongle. Gets data from another decoder like dump1090.
https://github.com/abcd567a/mm2/blob/master/README.md
ModeSDeco2:
Requires a dedicated dvbt dongle.
https://github.com/abcd567a/md2/blob/master/README.md
« Last Edit: August 30, 2019, 01:44:02 AM by abcd567 »
Offline abcd567
  • Member
Re: Automated Installation of ModeSMixer2 & ModeSDeco2 on RPi
« Reply #1 on: August 22, 2019, 02:39:57 AM »
UNINSTALL
To uninstall completely and remove all files, give following 4 commands:
ModeSMixer2
Code: [Select]
sudo systemctl stop mm2
sudo systemctl disable mm2
sudo rm /lib/systemd/system/mm2.service
sudo rm -rf /usr/share/mm2
ModeSDeco2
Code: [Select]
sudo systemctl stop md2
sudo systemctl disable md2
sudo rm /lib/systemd/system/md2.service
sudo rm -rf /usr/share/md2
« Last Edit: August 30, 2019, 02:47:20 PM by abcd567 »
Offline abcd567
  • Member
« Reply #2 on: August 30, 2019, 02:40:29 PM »
PLACEHOLDER
Offline Oldfella
  • Member
« Reply #3 on: November 23, 2020, 03:57:53 AM »
Many thanks abcd567 for all your help in making this hobby that little bit more enjoyable.
Just upgraded to a Pi 4 with a M.2 SSD and rather go thru the former step by step setting up of ModesMixer2 instead used your easy installation program. Worked like a charm.  ;D
Special thanks also to Sergsero for all his efforts in making ModeSDeco2 and ModeSMixer2 available to us.
Appreciate both your efforts.
Noel
Oldfella
