April 28, 2025, 09:17:28 AM
SBS-3 does'nt switch from USB mode to Network mode
Started by F5AHD, October 14, 2019, 06:19:16 PM
OK, I can see the problem.
I was using version 7.6.20.  You are using 7.6.21.  When I upgraded to 7.6.21 the option to Provide One-Time access has disappeared.
Searching the RemotePC website it now says that this feature is only available for Paid accounts.  Sneeky.
F5AHD
Ok, i installed the paid version.
AccessId = 519579937324 key =3623
See attachment
I am connected to your PC.  Do you see the Chat box?
I waited 5 minutes and no reply to the RemotePC Chat.  Have now disconnected.
F5AHD
F5AHD
yes, see attachement
Just to update this thread.
I made a remote connect and could see the SBS-3 responding to a Ping on 192.168.1.170.  I ran the Lantronix utility which resets it to the default 192.168.1.170:10001.  The Ping still responded.
But BaseStation couldn't connect to the SBS-3 with the data source set to Use Network and the IP address and port as 192.168.1.170:10001.
DC supply swapped, Ethernet cable confirmed as Straight.  Local firewall turned off.  All rather perplexing.
Andre will arrange to test the SBS-3 on a friend's setup but this may take a few weeks to arrange.  I've never known an SBS Ethernet port to fail.  This could be the first.
F5AHD
Hello Mike
I finally found time to get back into this problem.
On the hardware side there is nothing changed, I use the same DC and Ethernet cables.
On the software side, I decided to uninstall and re-install Basestation. I start Basestation in USB mode, and when I switch to Ethernet mode it is immediately recognized.
The Ethernet card is not defective as we had assumed. I tested both cases:
1 BaseStation and PlanePlotter operate in parallel. In this case PlanePlotter is connected to BaseStation by port 30006
2 Planeplotter works in standAlone? In this case PlanePlotter is connected to BaseStation by port 10001.
The problem is still with the network configuration. Unfortunately, I can no longer reproduce it.
As you took a long time to help me solve this problem, I had to give you this information.
Now that everything is working, this post can be definitively closed.
Greetings and a big thank you for your help and patience
vy 73 de F5AHD, André  :P
Hi Andre
Thanks for the update and I'm glad you managed to get the problem resolved.
