May 30, 2026, 08:40:23 PM
Need to run Modesmixer2 in a Docker Container
Started by shinesamuel, July 16, 2020, 08:58:28 PM
shinesamuel
Need help to run Modesmixer2 inside a Docker container.I am see a problem page comes up but no data shows up.
Here is the Log
020-07-16 15:52:49.983  INFO     outServer(sbs10001:10001) started
2020-07-16 15:52:49.983  INFO     outServer(avr:30030) started
2020-07-16 15:52:49.983  INFO     outServer(avr:30060) started
2020-07-16 15:52:49.983  INFO     outServer(avrmlat:40075) started
2020-07-16 15:52:49.983  INFO     outServer(msg:30014) started
2020-07-16 15:52:49.984  ERROR    outConnect(beast:feed.adsbexchange.com:30005) can't resolve host feed.adsbexchange.com Service not found
2020-07-16 15:52:49.985  INFO     outConnect(beast:feed.adsbexchange.com:30005) reconnect in 10 seconds
2020-07-16 15:52:49.985  ERROR    outConnect(beast:feed.adsbexchange.com:51138) can't resolve host feed.adsbexchange.com Service not found
2020-07-16 15:52:49.985  INFO     outConnect(beast:feed.adsbexchange.com:51138) reconnect in 10 seconds
2020-07-16 15:52:49.985  ERROR    outConnect(beast:feed.adsbexchange.com:51118) can't resolve host feed.adsbexchange.com Service not found
2020-07-16 15:52:49.985  INFO     outConnect(beast:feed.adsbexchange.com:51118) reconnect in 10 seconds
2020-07-16 15:52:49.985  ERROR    outConnect(beast:data.avdelphi.com:24999) can't resolve host data.avdelphi.com Service not found
2020-07-16 15:52:49.985  INFO     outConnect(beast:data.avdelphi.com:24999) reconnect in 10 seconds
2020-07-16 15:52:49.985  ERROR    outConnect(avr:feed.adsbexchange.com:30005) can't resolve host feed.adsbexchange.com Service not found
2020-07-16 15:52:49.985  INFO     outConnect(avr:feed.adsbexchange.com:30005) reconnect in 10 seconds
2020-07-16 15:52:49.985  ERROR    outConnect(avrmlat:feed.adsbexchange.com:30005) can't resolve host feed.adsbexchange.com Service not found
2020-07-16 15:52:49.985  INFO     outConnect(avrmlat:feed.adsbexchange.com:30005) reconnect in 10 seconds
2020-07-16 15:52:49.985  ERROR    inConnect(192.168.0.150:30030) can't resolve host 192.168.0.150 Service not found
Shine Samuel
Have you tried asking in the ADSBExchange Fourm?
Give as much info as you can. Be as clear as you can and hopegfully they will be able to help or point you in the right direction
https://www.adsbexchange.com/forum/
Oblivian
Appears to be the same as this
https://radarspotting.com/forum/index.php/topic,2978.msg46992.html#msg46992
What image? He is using DietPi. And it can't init the basic resolve function of the app
shinesamuel
   After installing dnsmasq package inside the container the problem got resolved.
Thank you
