May 16, 2025, 09:15:01 PM
Does anyone have the Custom Country Flag content enabled?
Started by gonzalu, December 04, 2020, 07:46:25 PM
gonzalu
I am giving this mod a try:
https://github.com/dedevillela/VRS-Country-Flags
But I can't get the images to show... seems like the directory names and the JavaScript are different as is the instructions screenshot.
folder calls for ../images/web-country/... but actual folder name is "country"
Then there is the whole HiDpi and what not.. .the script points to Width and Height directories that do not exist :(
Thank you!
/Manny
Artilect
Oddly enough this was first plug-in I tried and worked right off the bat.  Subsequently other plug-ins have cause me many headaches.
Perhaps clear your cache and restart browser?
This one I ended up not using because of resizing the table still leaves a gap.  If the country label could be suppressed or hidden like the Transponder flag then would visually be more appealing.
gonzalu
Quote from: Artilect on December 05, 2020, 05:28:29 AM
Thanks... I kept at it and ended up figuring out I needed to give a root path LOL... didn't even bother to look at the FULL screenshot on the instructions :P
cheers!
/Manny
motokops
Where is CountryFlag.html?
motokops
Yes. I saw and studied it, I can't find the file called CountryFlag.html in the download and CountryFlags.js it does not work.
I don't know how to configure it...
gunterb
The screenshot has not been updated. Replace the "CountryFlag.html" with "CountryFlags.js". Then it will work.
Regards g.
motokops
 It doesn't work for me.  ???
I will find another way to see the flags.
