January 18, 2022, 04:41:24 AM
Members
Stats
  • Total Topics: 13657
  • Online Today: 47
  • Online Ever: 164
Users Online
Users: 2
Guests: 34
Total: 36
10th January 2022
Wanted:
Ride Share
Latest Post
Latest File
Radarspotting.com. The first 10 years and the next?
This month marks the forum's 10th anniversary.  Please read this post.
Author Topic: LNA + filter installation  (Read 1224 times)
Offline motokops
  • New Member
« on: February 17, 2021, 09:13:34 AM »
I have this band pass filter and this amplifier LNA. What would be the correct and most effective order of placement respecting IN and OUT?
Antenna --- xxxxx  ----   xxxxx ----- USB RTL SDR receptor
Offline Anmer
  • Administrator
  • Top Poster
Re: LNA + filter installation
« Reply #1 on: February 17, 2021, 09:22:54 AM »
Is it powered?
Offline motokops
  • New Member
« Reply #2 on: February 17, 2021, 09:35:39 AM »
Yes, of course.
All OK. Working perfectly. I just want to know the correct order so that it works fine. IN/OUT
« Last Edit: February 17, 2021, 09:43:49 AM by motokops »
Offline Anmer
  • Administrator
  • Top Poster
« Reply #3 on: February 17, 2021, 09:45:18 AM »
Maybe:
Antenna - Filter - Amplifier - Receiver
No point amplifying data you don't need?
Offline motokops
  • New Member
« Reply #4 on: February 17, 2021, 09:59:30 AM »
is a good logical answer
Offline abcd567
  • Member
« Reply #5 on: February 23, 2021, 12:38:46 AM »
Maybe:
Fully Agree.
Just to see the difference, run an RF scan covering full frequency range of the dongle (24 Mhz to 1800 Mhz) in both the orders i.e.
Antenna>Filter>Anplifier>Dongle
Abtenna>Amplifier>Filter>Dongle
NOTE: This scan is pretty fast. One sweep across 24 Mhz to 1800 Mhz takes about 3 to 5 minutes. Few sweeps are enough
Do I Need A Filter - OPTION-4
« Last Edit: February 24, 2021, 03:06:07 PM by abcd567 »
Offline motokops
  • New Member
« Reply #6 on: March 01, 2021, 12:58:26 AM »
I have done the test   Antenna - Filter - Amplifier - Receiver
The filter and amplifier works very well.
In the attached file the result
