May 23, 2025, 06:12:58 PM
Ethernet setup issue
Started by mw0cvw, September 01, 2012, 04:03:13 PM
mw0cvw
Hello
Trying to get the PC to talk to SBS-3 over the Ethernet.
Connected via USB to confirm the following settings.
Hardware Settings (Network) Bast Station Software.
192.168.1.40
None Volatile Memory Settings
Ethernet Setup Tab
IP 192.168.1.40
Gateway
IP 192.168.1.1
DHCP IP Range is 192.168.1.1 to 192.168.1.200
Remove USB lead cycle power to SBS-3 still no Ethernet light.
Confirmed USB lead now disconnected.
Confirmed I can ping the IP Address of 192.168.1.40 with Dos command prompt in Windows 7
Any suggestions or have i missed a step  :)
Paul
Mw0cvw
In Basestation have you set connection to "Use Network"?
mw0cvw
Anmer,
Yep the green eyed monster again. ;D
Data source was set at USB
Once changed to ethernet the amber light is working on SBS-3.
Many thanks
Paul
Mw0cvw ;D
mw0cvw
Anmer,
Thanks, all working over Ethernet now.
VLC Media player now working also,stream audio from SDR to PC.
Very impressed with SBS-3.
Paul
MW0CVW ;D
