March 22, 2023, 06:04:19 AM
Members
  • Total Members: 6508
  • Latest: baz376
Stats
  • Total Topics: 13929
  • Online Today: 28
  • Online Ever: 783
  • (December 28, 2022, 05:15:59 PM)
Users Online
Users: 5
Guests: 17
Total: 22
Latest Post
Latest File
Author Topic: New install modesdeco issue  (Read 565 times)
Offline B767336
  • New Member
« on: October 18, 2022, 12:08:18 PM »
Got the setup using Zadig,Flightaware dongle and then modesdeco and this works really well with base station.
Got a new pc so thought it’d be easy to do the same, but something not going right.
First error message was the msvcr100.dll was missing. Thats now download and placed in the modesdeco folder but I now get the error message, “application unable to start correctly (0xc000007b).
If anyone can point me in the right direction I’d be extremely grateful.
Thx
Offline Anmer
  • Administrator
  • Top Poster
Re: New install modesdeco issue
« Reply #1 on: October 18, 2022, 01:37:15 PM »
Did you make a succesful install of Zadig on the new PC?
When do you see the error message?  When running ModeSDeco?
Offline B767336
  • New Member
« Reply #2 on: October 18, 2022, 04:34:32 PM »
Zadig says installed correctly when I run with dongle plugged .
The error message appears when I open the batch file so I see the small black window but can get no further….
Offline Anmer
  • Administrator
  • Top Poster
« Reply #3 on: October 18, 2022, 04:51:25 PM »
I failed to get ModeSDeco to run on my Windows 10 PC.  ModeSMixer runs fine.
Are you on the same version of Windows on both PCs?  And are they 32 or 64 bit?
Offline B767336
  • New Member
« Reply #4 on: October 19, 2022, 11:09:56 AM »
They’re both 64 bit machines, the first W10 pro and the new one W10 home.
Offline Anmer
  • Administrator
  • Top Poster
« Reply #5 on: October 19, 2022, 02:03:06 PM »
This may help.  I received an email from a member who'd had problems getting ModeSDeco to work:
I am pleased to say that I have had some success with ModeSDeco today.
In fact I now have it running on my notebook and can see aircraft on the map.  The solution was to re-install two of the .dll files - this time I downloaded 32bit files and deleted the 64 bit files, even though my notebook is 64 bit.   This was something that I think Sergsero suggested in his earlier post in that very long thread (approx page 69).
Offline B767336
  • New Member
« Reply #6 on: October 20, 2022, 11:47:13 AM »
I haven’t done this on previous installs and don’t know enough about pcs to be happy deleting files from the windows folder without a way to recover the situation. Could I remove the 64 bit files and save them elsewhere before installing the 32 bit files ?
I believe youre referring to the 2 files in the notes within the modesdeco folder ? Msvcp141.dll and msvcr141.dll ?
Very much appreciate the assistance.
Offline Anmer
  • Administrator
  • Top Poster
« Reply #7 on: October 20, 2022, 11:58:48 AM »
Let me contact the member who resolved his problem and check what files he replaced.
Offline abcd567
  • Member
« Reply #8 on: November 05, 2022, 12:54:34 AM »
No need to UNINSTALL any version of Microsoft Visual C++. I have ALL the following installed on my Windows10
Download Link 2015
https://www.microsoft.com/en-ca/download/confirmation.aspx?id=48145
I use: modesdeco2_windows_20180429
Download Link: https://github.com/abcd567a/mm2/releases/download/v1/modesdeco2_windows_20180429.zip
Code: [Select]
2022-11-04 20:59:01.393  INFO     ModeSDeco2 v.20180429
2022-11-04 20:59:01.446  INFO     Device: 0 mnf: Generic prod: RTL2832UFA serial: 00000978
2022-11-04 20:59:02.480  INFO     Supported Gains (dB):  0.0 0.9 1.4 2.7 3.7 7.7 8.7 12.5 14.4 15.7 16.6 19.7 20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48.0 49.6
2022-11-04 20:59:02.480  INFO     Freq Correction: 0 ppm
2022-11-04 20:59:02.565  INFO     Gain: 49.6 dB
2022-11-04 20:59:02.580  INFO     AGC: Off
2022-11-04 20:59:02.580  INFO     Start AVR Server on port 30002
2022-11-04 20:59:02.580  INFO     Start Beast Server on port 30005
2022-11-04 20:59:02.580  INFO     Start SBS10001 Server on port 10001
2022-11-04 20:59:02.580  INFO     Start MSG Server on port 30003
« Last Edit: November 05, 2022, 01:23:31 AM by abcd567 »
