April 30, 2025, 06:56:08 PM
Alternative Image Solutions for VRS?
Started by dodsy1, November 12, 2023, 11:23:45 AM
dodsy1
With Airport data down yet again, is there any alternative options to show aircraft images within VRS specifically on the beta 3.
Faramir
Been busy with that also. Add the images you want to show (you need the image files) and store them in de photos directory in your VRS environment. Add as path /root/.local/share/VirtualRadar/photos in the WebAdmin. That should do it. Getting the images is the hard part :-)
dodsy1
Quote from: Faramir on November 12, 2023, 09:06:05 PMBeen busy with that also. Add the images you want to show (you need the image files) and store them in de photos directory in your VRS environment. Add as path /root/.local/share/VirtualRadar/photos in the WebAdmin. That should do it. Getting the images is the hard part :-)
Yeah. I know of that option, but it's not really an easy solution given the sheer number of aircraft around.
I would also point out that the path that Faramir has given for the Pictures / Photos folder will vary depending on how, where and which operating system you installed VRS on. If you are running VRS from within the SDR-E VRS docker container then the path given is 100% correct. On every other set-up it will fail.
Faramir
Thanks Rik, I forgot to mention that. My apologies.
