May 21, 2026, 12:37:39 PM
ADU SBS Utility
Started by Magic440, June 29, 2024, 09:55:41 AM
Magic440
On opening up the above this morning,i had a Microsoft.NET Framework error pop up. ODBC-connection to 'SQLite3 Datasource'failed.
On clicking continue it just appears.
Anyone any advice please?
Thank you.
Magic.
Quote from: Magic440 on June 29, 2024, 09:55:41 AMOn clicking continue it just appears.
What "just appears"?
Magic440
Sorry Mike,ment to say reappears.
Is your active sqb file mapped correctly in ADU?
Magic440
Not sure how i can check that Mike?
I don't use ADU but I assume there's an option to set the path to your sqb file?  If you can find that and then let us know the path?
Magic440
Nothing that i can see Mike,lets you select the path to the SQB file. But it seems to be working ok now for some reason.
Just switched the laptop on,and all is good.
Magic.
Good to know it's working OK now.
But I would guess there's an option to set the path somewhere.  Otherwise, ADU won't know where the sqb file is located.
