April 18, 2026, 03:19:28 PM
ModeSMixer2
Started by Dreamliner787, March 11, 2025, 06:22:59 PM
laxlou
Quote from: Anmer on March 13, 2025, 03:05:21 PMCan you post a photograph of the FR24 receiver you are using?
I'm sharing data to FR24 and am using MSM2 to access data from the RPi.
I have been sharing years and original receiver had to be changed few years ago. This one have been running since then. I look some my notes and looks like on Aug 2024 data was still valid. There have been some update to system on autumn 2024, I think data which is displayed is shown bit differently comparing earlier ones. What I have not yet done is to more deeply check that raw port30003 output.
Otso
Thank you.  My FR24 receiver is over 10 years old!
I have sent an email to a contact at FR24 to see if there have been any changes.
laxlou
Quote from: Anmer on March 13, 2025, 03:48:40 PMThank you.  My FR24 receiver is over 10 years old!
I actually asked some time ago that do they have changed anything. I got reply that nothing has been changed. Just still wondering that maybe some small changes on that port standard output. This is interesting and many thanks about your help about digging this out. I can also provide more data regarding that output. The mm2 installation on rpi4 has been basically untouched during this period.
Otso
Where are you viewing the port 30003 data from the FR24 receiver?
laxlou
Quote from: Anmer on March 13, 2025, 04:49:38 PMWhere are you viewing the port 30003 data from the FR24 receiver?
Currently I just use that mm2 to create that Jetvision globe-s formatted data output which I am then again parsing using own Python scripts. One thing which I am wondering is that some change on that receiver port30003 output is now causing inproper output of that globes feed. When quickly looking that raw port30003 data ie. logging it via Pytty, data definitely include ID fields like this:
ID,,333,476426809,47A50D,476426909,2025/03/13,16:56:11.655,2025/03/13,16:56:11.655,NSZ2613
But for example this data is now never passed again into that globes output. All callsigns are not anymore displayed there. Also looks like all short MODE-S messages are not displayed properly. This lack of data can be seen also when using mm2 web statistics output.
Otso
Can you access the SD card in the FR24 receiver?
laxlou
Quote from: Anmer on March 13, 2025, 05:11:42 PMCan you access the SD card in the FR24 receiver?
I have never done that as the receiver is maintained by FR24. My only intention is to have ability to access that port data which is actually nowadays limited to that port30003 only. For example raw binary data is not anymore available for feeders. Also for physical access to device currently is limited as I am running receiver on remote location.
OK.  You will be able to access the card but it means opening the receiver. This occurs all the time, I know as I setup Support for FR24 and FlighAware!
Unfortunately I don't have an FR24 receiver or the latest SD card image to test.
Let's see if I get a reply from FR24.
This is the response I got from FR24.
Maybe contact FR24 Support?
QuoteWe do support raw data ports but they are disabled by default. The host needs to request opening them afaik.
laxlou
Quote from: Anmer on March 13, 2025, 07:12:13 PMThis is the response I got from FR24.
This is really interesting. I have long time since asked also that and they responded that they are not gonna open them. But if this is a case now and ie. good old raw 30005 can be opened, situation will be much better then.
Anyway in the meantime I tested here to connect that current FR24 receiver port30003 with different modesmixer2 version (running on Windows) than used in rpi4 mm2. Situation was same, and no any callsign etc. decoding.
Thanks for your reply, I will contact them once more to check this out and come back here for results.
Otso
laxlou
I actually didn't get any reply to my raw port question from FR24, but few days a go I noticed that port30003 data flow seems to be back to normal like it was earlier. Looks like FR24 receiver have been got update some time ago and after that full MODE-S data with also callsigns are now properly parsed via modeSmixer.
So, I didn't made any changes to my setup, it was just running like previously.
But all good now, have to to hope that this situation will last.
Otso
Glad to hear it's all OK now.  Bit disappointed that FR24 Support didn't get back to you.
