April 18, 2026, 05:59:50 PM
Carlos
Thanks Carl.
What's the folder/directory path for modesdeco2.exe?
And do you have this as a .bat or .txt file?  The screenshot shows a .txt file?
Maybe this link will help?
https://www.rtl-sdr.com/tag/zadig/
The video is no longer available, but the the text seems relevant:
The process to install an RTL-SDR dongle on Windows involves the simple step of running Zadig and installing the generic WinUSB drivers to the RTL-SDR, which shows up as "Bulk-In, Interface (Interface 0)" in Zadig.
However we find that people sometimes accidentally use Zadig to install WinUSB to "Bulk-In, Interface (Interface 1)" by mistake. Installing WinUSB to this interface can break your installation, and it can cause the RTL-SDR to display a "usb_open error -12" on command line software, and can cause problems connecting to the device on GUI software like SDR#.
Maybe re-running the zadig install to make sure you have 'Interface 0' selected, or maybe modifying your batch file to change device-index to 1 instead of 0.
I'd probably go for the first option, re-running zadig.
Hope this helps!
Carlos
The location is directly on the c drive. I just copied the setup I have on my tablet.
The txt file is the release notes from Sergsero.
I double checked the swift and it is 0 rather than 1.
Carl
Carlos
I don't use ModeSDeco2 but did manage to get it running on Windows 64 bit.  This was last year and trawling through emails etc,I found I needed to replace some 64 bit dll files with 32 bit versions.  But I can't remember or track back to identify which dll files they were!
Did you install 32 bit dll files?
Carlos
I installed in syswow64 but I might not have done all the ones required. I will double check on his laptop to see if I have missed any.
Carl
Carlos
I thought I'd give an update on the install issue.
We copied over missing msvcp and msvcr files to his new laptop from his old laptop but unfortunately it still wouldn't work.
However, installing drivers from zadig 2.8 rather than the older version we were using seems to have done the trick as modesdeco2 and his basestation are now working.
Carl
Thanks for the update and explanation of what fixed the issue.
evangel
Hello Anmer
it has been almost 2 years since I visited.
I have tried to revive and enhance the original ModeSmixer by Sergsero (apparently due to war disappeared).
So I am happy to announce today the revived MM2026 for Windows, with some extra features and enhancements by using AI and Claude.
Please advise if shall where shall I upload it, here or in the Downloads ?
Thanks and Best Regards
Evangel
PS few images here...
Welcome back.
Looking at your images, you've created a new user interface for displaying tracked aircraft?
ModeSMixer allowed data from one or more sources to be output in various formats.  There was no user display interface.
We would be pleased to host your application.  Do you have any support or user documentation?
I will have to upload the relevant files to the Software section.  Please email me:
admin at radarspotting dot com.
evangel
hi Anmer
still working some minor details and I will contact you
at the email you provided with the attachment. it will be also
a full report for  the user.
best regards
Evangel
evangel
moved to new position by Anmer !
