May 06, 2024, 02:13:50 PM
Font size/colour in Basestation Reporter
Started by Magic440, July 09, 2014, 08:47:45 PM
Magic440
Is it possible to change these? I would like it to be bigger/darker.
Thanks in advance.
I don't think you can change the font in Reporter.
deedaa1950
can the number of characters be altered to increase the number in each column from 10 to whatever
I'm away from home so can't check.  Not sure if one can modify the sql database.  Or if the Reporter.ini has options.
What columns do you want to change?  Some changes may impact on BaseStation.
Truetrack
re permissable number of characters the fieldlength in Reporter is defined in
BasestationReporter.INI in diff locations these are
[MainFormAircraftDBGrid]
[MainFormFlightsDBGrid]
[MainFormSessionsDBGrid]
Sorry I cannot say whether these sizes were triggered by initial setup
of Basestation, or what effect to Basestation and the SQB-File !
As usual make backups (incl virtual Store if used) before fooling around,
or arrange for a second copy in a complete different folder to play with.
Klaus
