May 11, 2024, 10:16:50 PM
microADS-B IP receiver Radio Frequency Interference
Started by qc91, April 12, 2015, 09:05:25 PM
qc91
Hi, I have a microADS-B IP Receiver and have notice RFI Radio-Frequency Interference From 18.180 MHz to 155.5860 MHz I used 3 different test radios and confirmed that I only get Radio Frequency Interference when the ADSB receiver in turn on if you can setup one at your office with Plane Plotter or ADSBScope with transferring data. I have tried using Ferrite Core on the power supply and on the Cat5E that has shielded I also tried different power supplies but it did not remove the RFI, I have tested and found the Interference on vertical and horizontal antennas and I also used portable antenna you have to be within 20 to 30 feet of the microADS-B IP receiver just wanted to know if anyone else found RFI on there microADS-B IP?
Usually it's the DC power supply that causes such interference.  Do you have another one you can try?
