May 05, 2024, 08:55:39 PM
Puck Problems again!
Started by Nigel, January 19, 2016, 09:11:28 PM
Hi Ian
Have you tried reloading the USB drivers?
Ian K
Ian K
Just run the CDM20814 Setup.exe ..let's see if it works
Ian K
Well, that hasn't worked, lasted 8 mins before dropping out again .
Did you first uninstall the existing drivers?
May not be relevant to the immediate problem but for future reference this post goes on about dealing with poor connections between cable and Puck.
http://forum.planefinder.net/threads/hacking-1090-puck-usb-cable.209/
May be related to the earlier comments about using alternative cables from the one supplied with the puck.
Ian K
#36
I didn't uninstall.
Tried sbs-1 with same issue, now trying different usb cable. if still fails i will uninstall drivers
Ian K
The usb drivers are  showing as 22/01/2016
Nigel
After a number of frustrating months of connection problems I finally decided to try a different USB cable (the one from my portable hard drive!) and now the Puck seems to be working fine again. I know that this had been suggested on the forum but had considered the cable not to be a problem because sometimes the Puck worked fine for a number of days without disconnection.
Ian K
I also replaced my Active extension cable and have had no problems for 2 weeks.
