May 17, 2021, 08:27:53 PM
Members
  • Total Members: 6018
  • Latest: nexux
Stats
  • Total Topics: 13157
  • Online Today: 52
  • Online Ever: 131
  • (May 09, 2021, 12:28:05 AM)
Users Online
Donations
Donations help with annual costs and keep Radarspotting free of advertising. Thank you.
Latest Post
Latest File
15th May 2021. Mode-S Tweaker Version 1.1 now available for download.
If you're looking for a bulk download, we have over 66,000 aircraft silhouettes, profiles and operator logos available in bmp file format, 85x20 pixels. You can find all the Zip files here.
Some of the Latest Additions:
Author Topic: Dump1090 Mutability and BaseStation  (Read 3281 times)
Offline Oldfella
  • Member
« on: July 19, 2016, 06:34:20 AM »
Looking for assistance to setup Dump1090 Mutability V1.15 on a Raspberry so that it can feed BaseStation and PlanePlotter on a home network. Been successful with PlanePlotter but unable to connect BaseStation. Has any other member been successful?
Currently reconfigured Mutability for the default sbs port 30003 but will not connect.
Any assistance would be very much appreciated.
TIA,
Oldfella
Oldfella
Offline Anmer
  • Administrator
  • Top Poster
Re: Dump1090 Mutability and BaseStation
« Reply #1 on: July 19, 2016, 08:00:22 AM »
For BaseStation I think you will need to use ModeSMixer.
Not that I've tried it myself.
Online Triple7
  • Member
« Reply #2 on: July 19, 2016, 08:50:08 AM »
Anmer is correct you will need to install ModeSMixer2 to pick up the feed from the dongle and transcode it into BaseStation format.
I tried something similar using a laptop and a dongle and posted a set of set-up instructions for feeding into BaseStation, I can't seem to locate the link atm but I'll keep searching and add to this thread.
EDIT: http://radarspotting.com/forum/index.php/topic,2978.msg24197.html#msg24197 gives some notes on settings for using ModeSDeco2 and taking the feed into BaseStation via ModeSMixer2. Using Dump1090 Mutability in place of Deco2 should also work - you just need the ModeSMixer2 part of my notes.
MM2 can be found here: http://radarspotting.com/forum/index.php/topic,2978.msg15240.html#msg15240
Instructions (but will need a bit of amendment) here: http://radarspotting.com/forum/index.php/topic,5175.msg26404.html#msg26404
and some further info here: http://radarspotting.com/forum/index.php/topic,3938.msg18434.html#msg18434
for the --inconnect command I use the specific IP address of the RPi and I use
Code: [Select]
--outServer sbs10001:10001 --outServer sbs30006:30006
« Last Edit: July 19, 2016, 09:06:08 AM by Triple7 »
Offline Oldfella
  • Member
« Reply #3 on: July 19, 2016, 11:29:50 PM »
Thanks Anmer and Tim for the links.
Will have a play around with ModeSMixer2 over the week and see what develops.
I'm able to feed PlanePlotter using Dump1090 Mutability and somehow gained the impression that it could also feed BaseStation.
Oldfella
Oldfella
Offline Anmer
  • Administrator
  • Top Poster
« Reply #4 on: July 20, 2016, 07:53:23 AM »
I think the data format needs manipulation before it can be used by BaseStation.
Offline IanH
  • Top Poster
« Reply #5 on: July 20, 2016, 01:52:40 PM »
I've just tried Tim's instructions and they worked.
On the Windows PC, create a batch file containing these instructions:
Code: [Select]
@echo off
cmd /c  <<path to modesmixer2.exe>> --inConnect <<Rpi IP address>>:30005 --outServer sbs30006:30006 --outServer sbs10001:10001 --location xx.xx:-y.yy
PAUSE
exit
Substitute the location of modesmixer2.exe (for example mine is c:\radar\modesmixer2.exe)
and the Pi's IP address.
You should get data out on port 30005 which is then converted to SBS10001 and SBS3006 formats.
SBS30006 is for PlanePlotter using DirectIP and SBS10001 is for BaseStation.
In Basestation, under Settings/Hardware Settings/Network, enter Address; 127.0.0.1 and Port: 10001
Edit: Looking back at the original post, port 30003 was never going to work as input to Basestation software. - that is what comes out of Basestation software! The software needs whatever the format is on port 10001 from the Basestation hardware and ModesMixer2 knows how provide that.
« Last Edit: July 20, 2016, 03:04:03 PM by IanH »
Offline Oldfella
  • Member
« Reply #6 on: July 21, 2016, 12:00:35 AM »
YOU LITTLE BLOODY BEAUTY!
(sorry for the shouting -I'm up on the rooftop with my ADS-B antenna)
Thank you both Ian and Tim. I have been playing around with this for a week now, trying all sorts of combinations and then with your inputs, it all fell into place.
A very happy little vegemite.
Oldfella
Oldfella
Offline Anmer
  • Administrator
  • Top Poster
« Reply #7 on: July 21, 2016, 07:59:51 AM »
Offline Oldfella
  • Member
« Reply #8 on: July 21, 2016, 12:43:17 PM »
... and of course, you too Anmer, you are the brains behind the whole shooting match. Without you we wouldn't be here, we would still be trying to get answers over on the "K" site.
« Last Edit: July 21, 2016, 12:44:58 PM by Oldfella »
Oldfella
