May 19, 2025, 10:52:08 PM
Filters
Started by Turbo68, December 04, 2017, 01:19:12 AM
Turbo68
Does anybody use a filter to improve the range on the SBS-3..
Regards Lino.
I've used a band-pass filter to reduce RF interference when using a DVB-T SDR "dongle" but don't need it in my rural location where there is no interference.
https://www.amazon.com/dp/B010GBQXK8?tag=fligh01-20
I'm not aware of a filter that can improve the range of the SBS-3 which probably has an in-built filter.
What filter were you thinking of using?
Turbo68
I already got 2 of the flightaware filters and work very well also been thinking of using the Uptronics HAB 1090MHZ ADSB Preamp with a bias-tee..
Regards Lino.
Quote from: Turbo68 on December 04, 2017, 11:06:38 AM
Ah, that's different.  I use a masthead preamp and Bias-T from Wimo and tested a similar kit a few years ago.
See:
https://radarspotting.com/forum/index.php?action=tpmod;dl=item11
Turbo68
I already have a masthead amp on my ZMX beam works excellent furthest range i got with that has been 438nm very happy with that ordered a bias-tee 10mhz-7ghz on ebay..
Regards Lino..
