January 18, 2022, 04:15:09 AM
Members
Stats
  • Total Topics: 13657
  • Online Today: 47
  • Online Ever: 164
Users Online
Users: 0
Guests: 44
Total: 44
10th January 2022
Wanted:
Ride Share
Latest Post
Latest File
Radarspotting.com. The first 10 years and the next?
This month marks the forum's 10th anniversary.  Please read this post.
Author Topic: How to Change Serial Number of DVB-T Dongle  (Read 2425 times)
Offline abcd567
  • Member
« on: July 24, 2018, 06:33:28 PM »
The default serial number of Generic DVB-T is generally 00000001, and that of a Flightaware ProStick is generally 00001000.
In tutorial below the serial number will be changed to 00000000.
You can however change to some other number also if you want. For example you want to use 2 dongles in one RPI as follows:
(1) One dongle used by dump1090 and other dongle used by dump978
OR
(2) One dongle used by dump1090 and other dongle used by AcrsDeco2
You can assign serial # 00000000 to the one for dump1090, and serial # 00000001 to the other for dump978 or AcarsDeco.
Click the link below (or scroll down to next posts) to see these options:
(A) Dongle Plugged into Raspberry Pi
(B) Dongle Plugged into Windows Computer
« Last Edit: July 24, 2018, 06:40:20 PM by abcd567 »
Offline abcd567
  • Member
Re: How to Change Serial Number of DVB-T Dongle
« Reply #1 on: July 24, 2018, 06:35:32 PM »
STEP-1
Install the test tools package rtl-sdr
Code: [Select]
sudo apt-get update
sudo apt-get install rtl-sdr
STEP-2
First stop the dump1090 to make Dongle free for use by rtl tools.
Code: [Select]
#Give one of the command according to version of dump1090 you have installed
#If you are not sure of version, give all three commands one by one
sudo systemctl stop dump1090
sudo systemctl stop dump1090-mutability
sudo systemctl stop dump1090-fa
STEP-3
Install package rtl-sdr, if not yet done.
The tool rtl_eeprom is part of package rtl-sdr
Code: [Select]
sudo apt-get update
STEP-4
Now give the command rtl_eeprom -s 00000000 to reset the serial number
The last line of output will ask confirmation to go ahead with change.
Type y and press Enter key
(Scroll down to see full code below)
Code: [Select]
Found 1 device(s):
  0:  Generic RTL2832U OEM
Using device 0: Generic RTL2832U OEM
Found Rafael Micro R820T tuner
Current configuration:
__________________________________________
Vendor ID:              0x0bda
Product ID:             0x2838
Manufacturer:           Realtek
Product:                RTL2838UHIDIR
Serial number:          00000001
Serial number enabled:  yes
IR endpoint enabled:    yes
Remote wakeup enabled:  no
New configuration:
Vendor ID:              0x0bda
Product ID:             0x2838
Serial number:          00000000
Write new configuration to device [y/n]? y
#After typing y and pressing Enter key, you will get this confirmation message
Configuration successfully written.
Please replug the device for changes to take effect.
Offline abcd567
  • Member
« Reply #2 on: July 24, 2018, 06:39:19 PM »
STEP 1
Install dvb-t rtl driver zadig if not yet done so, as detailed below.
(1) Download Zadig 2.3.exe from http://zadig.akeo.ie/
(2) Plug the DVB-T or ProStick in your Windows Computer.
(3) Follow the steps below:
(a) Double click Zadig 2.3.exe to run it.
The window below will open.
(b) On main menu, click "Options".
On the drop-down, place a check mark beside "List All Devices".
(c) From list of devices, select "RTL2838" which is actually DVB-T/ProStick.
Now click button which will either say "Install Driver" or "Reinstall Driver"
STEP 2
Download RelWithDebInfo.zip from here:
Download Link: http://osmocom.org/attachments/download/2242/RelWithDebInfo.zip
Web Page: https://osmocom.org/projects/sdr/wiki/rtl-sdr
(scroll down to bottom of page to find download link)
STEP 3
(a) First EXIT your RTL1090 or ModeSdeco2 or Flightradar24 feeder, or dump1090, or any other software which is using DVB-T to make the Dongle free for test.
(b) Un-zip RelWithDebInfo.zip. It will create a folder RelWithDebInfo.
Inside this folder there is another folder rtl-sdr-release which contains several files and 2 folders named x32 and x64.
(c) Go to folder x32. You will find many rtl tools in it as shown in screenshot below.
(d) In folder x32, right-click and create New Text Document
[/size]
STEP-4
Open the New Text Document and type
STEP-5
Save the file as change-serial.bat
While saving, make sure that
1. File name contains .bat at the end
2. "Save as type" is selected "All Files"
Please see screenshot below.
STEP-6
Double click the file change-serial.bat to run it
STEP-7
Upon double clicking the file change-serial.bat, command console will open, with last line asking confirmation to change serial number.
Type y and press Enter key. The serial number will change and command console will close immediately.
STEP-8
To check if the number has actually changed, again double click the file change-serial.bat, and it will show changed serial number.
Type n and press Enter key to close console
Using RTL1090 on Windows
Step-1
Open Command Promt, and give command C:\rtl1090>rtl1090.exe /eeprom
(My rtl1090.exe is located in folder C:\rtl1090, that is why I have used this path. You have to use the path in your computer)
Step-2
Click START button on RTL1090 window.
Step-3
Set serial number and press Continue button.
