May 03, 2024, 08:08:56 AM
Help with networking SBS-1er
Thanks for trying those checks.
I've sent you an email with a link and instructions to reset the Lantronix device.
Please try the reset.
Maxie39
Okay I will try it, thank you. I will let you know.
Maxie39
I've run the steps and now it works! Thank you very much for the quick replies on this old thread.
Quote from: Maxie39 on October 15, 2021, 03:11:40 PM
Great to hear it now works.
Just needed to eliminate other issues first.
alpha60uk
Hi all,
I am successfully using my SBS-1er with ethernet via my router but would like to share with other PCs on my network i understand this can be done using software called Multi-EM from jetvision but it seems they have moved on and no longer sell it is there anywhere else I can get a copy or is there and alternative?
Thanks in advance
Dean
Welcome Dean.
Unfortunately Multi-EM "disappeared" many years ago.
Do you plan to run Basestation simultaneously on your other, local PCs?
ModeSMixer might be a suitable alternative?
alpha60uk
yes I do, thanks Anmer I will explore modeSmixer
alpha60uk
Hi again Anmer this is confusing me do i have to run modesmixer2 on both PCs or just on the one that hosts the SBS-1ER
Dean
I've not used this myself (others here are more experienced) but I think you only need to run ModeSMixer on one PC.  Configure ModeSMixer2 to get data from the PC running Basestation using the SBS-1eR input.  Then set Basestation running on the other PCs and connect (as Network) to the PC running ModeSMixer2.
Anmer is correct. You only need to run MSM2 on one PC, either the one you run BaseStation on or another one on the same network.
In essence MSM2 picks up the output from your SBS (192.168.1.170 is the defualt IP addrerss) and rebroadcasts it on the network so any PC running BaseStation pointing at the MSM2 feed will run as though it is connected directly to your SBS.
I've been running mine that way for years and it runs flawlessly!
Good luck.
Quote from: Triple7 on January 28, 2022, 07:40:42 AM
Thanks Tim.
For my benefit, does MMS2 get the data direct from the receiver or from Basestation?
Faramir
My MSM2 gets the data direct from the SBS-1. However, first I connected BaseStation directly to the SBS-1 via the network connection to get the green network LED on the SBS-1 to turn on. Then set BaseStation to the IP address from the MSM2 machine and started MSM2.
alpha60uk
Thanks Faramir that explains it better I will give it a go
Dean
alpha60uk
Hi again guys trying to get this to work I have modesmixer2 on the host PC
this is my bat file
@echo off
cmd /c c:/modeSmixer2/modesmixer2.exe --inConnect 192.168.1.170:30005 --inConnect 127.0.0.1:30005 --outServer sbs10001:10001 --outServer msg:30003
PAUSE
exit
doesn't seem to work any idea what I am doing wrong?
thanks in advance
Dean
Hi Dean,
Your --inconnect ports are wrong! You can remove your '--inConnect 192.168.1.170:30005 --inConnect 127.0.0.1:30005 --outServer msg:30003' commands and replace with:
--inConnect 192.168.1.170:10001 --outServer sbs10001:10001
That should get you going.
And my apologies if my previous answer didn't explain things very well.
